    Senior Member Three Rings DJmuggs's Avatar
    Jul 03 2007
    1999 Audi A4 1.8t quo
    Is this bad for my clutch?
    Just wondering, is leaning my foot on the clutch (not applying pressure), while driving in gear bad for my clutch???
    Thanks,
    Deej
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    Re: Is this bad for my clutch?
    I'm not sure if its good or bad in our cars, but sometimes doing that can wear out the throw out bearing.
    Someone else can add more i'm sure..
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    If you're not engaging the clutch the throw out bearing is not being effected. If one is not applying pressure to the brakes are they being used, is the master cylinder being worn out? Nope:)
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    It really depends on how much weight you're pushing the pedal with.
    Personally, I don't do it, but I don't think it's going to increase wear.
    The amount of pressure it sounds like you're applying with your foot will only take up and slack in the system, and wouldn't increase the pressure of the system to any degree worth mentioning.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    is this not why we have a dead pedal ?
    -Nic
    My Car
    old junk new junk, red junk blue junk
