I am at whits end here. I am putting my motor back in after my stage 3 install. I got the motor in enough to put the slave cylinder in and now I am bleed the clutch. I have tried to bleed the clutch for 3 days now and it's still not right and I need some help. The pedal still does not return all the way up. Last night I was able to get the clutch pedal to return about 3/4 of the way, but not all the way. I have cracked the bleeder so many times it's now starting to strip. I replaced my master cylinder as well so I know there is more air than usual but it shouldn't take 3 days to bleed a damn clutch. I have a pressure bleeder, but at 20 inhg nothing will come out. When I combine that with the pump and hold method I can get fluid to come out, but I can't the damn clutch right. There are no leaks.
What the hell am I doing wrong? How do I get my damn clutch right? I just want to drive my car.
