View Poll Results: Which clutch to go with?
Voters
27. You may not vote on this poll
  • Southbend Stage4 FE disk w/ resurfaced stock DM flywheel.
    9 33.33%
  • #1 but with fidanza FW
    7 25.93%
  • Clutch masters stage 3/4 segmented disk (8 puck) with stock dual mass flywheel
    4 14.81%
  • #3 but with the CM lightweight flywheel
    7 25.93%
Results 1 to 14 of 14
    Jan 11 2007
    Salt Lake City, Utah
    Down to these: Southbend Stage 4 FE or Clutch Masters stage 4...
    I'm going to be running RS6's on E85 tune and need a clutch to handle that. It will be my daily driver 1st, weekend road racer 2nd, and very rare trip to the drag stip distant 3rd. So after much research there were a bunch of people who liked their FE SB clutch, with one reported incident of a fused disk to the flywheel. The research on the stage 4 fx400 CM had a lot of people that liked it as well, one reported case of it not disengaging, twentyvalveb5 went through his stage3/4 in about a year, and I've heard that it chatters even with the stock flywheel. So if you have experience either directly or indirectly with these setups, give me your input. If you don't, then don't give me your random guess:) What would you pick in my situation and why?:
    1. Southbend Stage4 FE disk w/ resurfaced stock DM flywheel.
    2. #1 but with fidanza FW
    3. Clutch masters stage 3/4 segmented disk (8 puck) with stock dual mass flywheel (only disk that will work with the stock flywheel)
    4. #3 but with the 6 puck disk and the CM lightweight flywheel
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: Down to these: Southbend Stage 4 FE or Clutch Masters stage 4...
    Personally I recommend a southbend clutch. I know a few people with S4's and some CRAZY setups and they all love em. My CM stage3 is on its way out from 12 track runs, few pulls, about 15-17 launches, 15-25 wot shifts. On a side note a friend of mine had a CMstage4, its a really harsh engagement, and it went after 30K or pure abuse.
    l gotta-- l gotta get
    a form from a scientist.
    Jan 11 2007
    Yeah I know the stage 3 CM and stage 4 and other stages SB have vastly different responses as well, that's why I'm trying to keep this strictly SB FE and CM stage 4 fx400 (6 puck most likely, just threw the stage 3/4 segmented disk up there as an option). 30k of pure abuse is pretty good at those power levels, no? (actually, what power level?)
    LOOKING FOR:
    Buncha motorcycles
    Memphis, TN
    southbend is now offering a stage 5 with a 8 puck fe/ceramic disk i believe. mike2ptzero can get it......
    several of the b6 guys have slipped or welded the FE SS clutch kits and are now going to the pucks.. i have the FE SS but not near enough power to slip it
    APR Stage 2/AWE Intake
    May 04 2004
    00 BB S4
    York, Pa
    South bend hands down.
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    I have SB stage 3 OFE, and haven't had a problem yet, although I haven't tracked the car and I've only put about 3k on the new clutch. I would check with SB and make sure that you can run that Fidanza LW flywheel with that clutch first.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    stg 4 is OFE. stg 5 is FE.... fwiw
    but i would steer clear of the OTS southbend setups if you are going to track/drag the car. but the OFE stg 4 is an amazing daily driver compared to the stg 5.
    if you are going to be aiming for 500whp that those rs6's will dish out, then you need a better setup than a clutch that has been getting people with 300-400whp by.
    look into the DXD 8 puck/full faced disk like mentioned before. or spend some coin on a twin disk setup.
    disclaimer: i've driven both the stg 4 and stg 5 clutches for over 25000 miles between the 2. and both with the Eurocode 800psi pressureplate option.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jan 11 2007
    Quote Originally Posted by sean1.8t View Post
    For the A4's your stages are correct. Not for the S4's stage 4 is FE and stage 5 is the segmented disk(?). Definitely not going to go with OFE setup, nor a twin disk, so it's FE, pucks or bust.
    LOOKING FOR:
    Jan 11 2007
    Interesting, the one getting the least votes is the one I'm leaning towards the most, CM stage 4 with CM flywheel
    LOOKING FOR:
    Sep 17 2006
    SLC, UT
    ah right. i guess i should have checked that before i posted. either way, stay away from the FE. far away.....
    Current:
    Previous:
    Jan 11 2007
    Still leaning towards CM stg 4 w/ CM LWFW, any more input?
    LOOKING FOR:
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    I am doing the Southbend Stage 4 with LWFW. I have heard about people fuzing the clutch to the flywheel, but that has only happened when people slip the life out of the clutch. And well if you are holding the revs high and slipping it, you shouldnt be driving stick in the first place Car is getting it installed tomorrow and Greg will be breaking it in before the tune, so you are welcome to ask him about it when he installs it and i can give you feedback when i get the car back
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    I have number 3 and I love it.
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by Evilevo View Post
    mine was on a 6k rpm drop. the only thing that slipped was my tires
    ok, well obviously the clutch slipped a bit on it otherwise it wouldn't have welded the way it did. but it was not more slip than you will normally see at a track visit
    Current:
    Previous:
