Results 1 to 28 of 28
    Nov 26 2006
    Memphis, TN
    Can you fit 255/30/19's on a B7 S4
    I have a B7 S4 and was wondering if you can fit 255/30/19 tires on a B7 S4? I am running OZ Ultraleggera's (19X8.5 ET35) with H&R coilovers. If I need to I can raise the coils up to avoid rubbing also.
    Thanks,
    Paul
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Re: Can you fit 255/30/19's on a B7 S4
    it will fit in the trunk. =)
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    hmm very possible, I ran a 245/35/19 on my pervious B7 S4 on 19x9 +29. I had to roll the sh!t out of the fenders to eliminate the rubbing, but that was due to the extreme offset.
    Well 255/30/19 is the WIDEST you can go on an 8.5 wide wheel (according to manufacture tire specs). So lets set that as the max. What size tire are you running now with the OZ wheels?
    If you are running lets say 235/35/19 on the OZ wheels right now, going to a 255/30/19 tire will increase your overall section width by .5"
    235/35/19 = 8.5" section width
    255/30/19 = 9.0" section width
    So the tire is going to buldge out slightly more on the sides compared to a 235.. about .25" outwards on each side. Which means you'll lose .25" of clearance between the fender and tire. I am pretty sure you won't rub, but don't take my word for it 100%. Go take rough measurement if you can from your tire sidewall to the fender now. Another experiment to try is jacking up one corner of the car so the opposite corner sinks down really low and the tire tucks. That should give you another idea of how close you already are and how much room you have to play with.
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    I believe with the STaSIS S4 set-up, they're running 255/30/19.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Sep 23 2006
    Houston TX
    you can even run 265-30-19, but thats ET37. I'd say you'll probably be fine, but with ET35 it will be close. You may need to trim a little liner, but that should be it.
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    there's an a4 running 275! but then you have to get wheels with a higher offset to accomodate. I will tell you that if you are lowered, 255 on 19x8.5 ET35 are not gonna work very well because 19x8.5 et35 w/ 245/35/19 are extremely flush on a stock suspension (for the front wheels, less so for the rear), so if you lower it and fatty the tires, i'm betting serious rubbing.
    Jan 29 2006
    08 RS4
    Quote Originally Posted by Ill 3.0 View Post
    agreed.
    Nov 26 2006
    Memphis, TN
    I am running 245/35/19 Contisport 3's right now with zero rubbing. I think I might just order one tire and see how it sets up before I order the rest.
    Jan 29 2006
    08 RS4
    Quote Originally Posted by OneFastBMW View Post
    wow those tires have a section width of 9.8" . The 255/30/19 tires I've been looking at have a 9" section width. So if that's the case and you have no rubbing now, you will def. be in the clear with 255/30/19 on the OZ wheel.
    Active Member Four Rings Kemiksiz's Avatar
    Feb 21 2006
    BMW F80 Conversion- Merc A Klasse
    Turkey
    Quote Originally Posted by Cargo8 View Post
    R u mentioning me?
    You can easily go with 255-30-19 with a liner screw holder remove.. I use it without ANY rubing issues..
    BTW I hve et35 with 8.5 rims with my 255-30-19's..
    Instagram: @m3_rhino
    Current
    B9 A4 Avant => RS4 Avant
    Done Projects:
    F30 => F80 Full Conv
    A3 => RS3 Full Conv
    Buick Tourer => Full OPC
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    People need to realize that with enough camber you can fit a very wide tire, but you have to make other sacrifices. Some are using huge tires but have to run some camber that they would have a greater contact patch on the normal sizes with less camber adjustments. And there is the wear issues.
    Veteran Member Four Rings S4DTM's Avatar
    May 26 2008
    '12 TTRS, '01 S4 Full 3.0L Racecar
    Moraga, CA
    Quote Originally Posted by ed@audiyo View Post
    Yup, my buddy is runnin 255/30/19s on his STaSIS S4 (i'm running 245/35/19s on mine). It all depends on the tire you use, because although they all say the same number, they differ in widths. His Toy Proxes 255s fit with no problem, but he tried the PZeros and they rubbed bad! Even sliced into the side of the tire. Just check your widths
    [COLOR="red"]l FRRG Northern Ring President l
    '17 Alfa Romeo Guila Quadrifoglio
    '01 S4 Racecar "Giggles" - Sponsored by 034Motorsport
    Four Rings Racing
    Gone but Never Forgotten:
    '07 S4 DTM
    ->'12 TTRS - Phantom, Titanium, CF Mirrors, Sport Exhaust, Tech, Butt Warmers, Tint and Clear Bra, APR Stage 1, 034 Midpipes, AWE Boost Gauge
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    yea my friend is running a 265 with no problems
    daworldisyours.com/forum<----check it out!!!!
    Nov 26 2006
    Memphis, TN
    Quote Originally Posted by KryptoniK View Post
    Where do I get the section width of the tires? IS this on the tirerack spec sheets?
    Nov 26 2006
    Memphis, TN
    Quote Originally Posted by Kemiksiz View Post
    R u mentioning me?
    Can you post a pic of the screw you are talking about. Or if you can just take one on a cell phone and e-mail it to me. I will PM my e-mail address if you can do that.
    Jan 29 2006
    08 RS4
    Yes you can find the section widths on Tirerack.com from the tires spec sheets.
    You can find the screw in the top of the front fenders, its right on the lip of the fender. All it does is hold the liner in on that spot, but even if removed the liner is still wedged in pretty tight. Whenever rubbing begins in the front, thats the first solution that almost always solves the problem.
    Nov 26 2006
    Memphis, TN
    Awesome, thanks alot. The tire I was looking for was the Michelin PS2 in a 255/30/19 and the specs were listed as NA on Tire Rack. After looking through the Michelin site I found out that the tire has a section width of 10.24" when mounted on a 9" wheel. Will this section width be bigger or smaller when mounted on 8.5" wheel?
    Also, I am pretty certain but not 100%. Don't Michelin's run a little smaller than other brands?
    Thanks for the help guys,
    Feb 21 2006
    Turkey
    No need the pics, as kyripto said, just put your fingers into the fender and nearly in the middl off it you will touch the little holder.. I just cut it away, ii'm just fne :)
    Please send us the pictures when u r done!
    Current
    Done Projects:
    A3 => RS3 Full Conv
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    I second that - please post pics. I want to run as wide without rubbing as possible without using camber.
    Feb 21 2006
    Turkey
    Actually I do not have any pictures right now, just check your inner fender by your fingers, through the middle point you gonna touch little D shaped holder. Cut it away and you'r done
    I think its 265/30/19 with 38 et, the possible widest setup.. of course depends of your tires' brand..
    Current
    Done Projects:
    A3 => RS3 Full Conv
    Veteran Member Four Rings dannyj777's Avatar
    Jun 01 2008
    2005 B6 S4 Avant Arctic White
    NorCal/SoCal
    i'm running 255/30/19 all around with no probs at all. Just make sure your offset is right. i love having the fatties on the S
    2005 B6 Avant Arctic White
    Nov 26 2006
    Memphis, TN
    Quote Originally Posted by dannyj777 View Post
    Please list the width and offset of your wheel as well as the type of tires.
    Thanks
    Jun 01 2008
    NorCal/SoCal
    Thanks
    19x9.5 et35 Volk CE28n special order from stasis via az. tires r toyo t1 and pzero depending on how bad americas tires wants to screw me. yes i know i need co's.
    Feb 17 2006
    PSA: some tires run narrow, while other brands run wide.
    Sep 16 2008
    Normal, IL
    Nice, I bet those are light as F for a 19x9.5 wheel.
    19x9.5 et35 special order from stasis via az. tires r toyo t1 and pzero depending on how bad americas tires wants to screw me. yes i know i need co's.
    Jun 01 2008
    NorCal/SoCal
    Quote Originally Posted by Captain Insano View Post
    you are correct. it really lightened up the steering which was my main complaint after coming from RWD cars. I don't have to fight the car at high speed turns any more. They weigh 18 lbs, vs. 28lbs stock. Dropping 40lbs at the corners is never a bad thing. After CO's and rear sway, she should be perfect. I'm just glad there is no rubbing, because I heard so many people having to strip their inside lining with 19's. It's all about the offset.
    Jul 02 2004
    FL
    After co's you may have some issues, my 245/35/19 on 19x9 et34 with H&R CO'c rub a little.
    Nov 26 2006
    Memphis, TN
    Quote Originally Posted by B18b1ex View Post
    How low are you dropped and what brand of tires are you running?
