Results 1 to 7 of 7
    Registered Member Two Rings
    Dec 02 2008
    98 a4 1.8tqm
    littleton
    Unhappy Help!!! abs+brake light
    just a couple days ago my abs and brake light started to go off, its weird because it only does it for about two minutes and then goes back to normal. the abs light stays solid and the brake light flashes. i checked the fuses and thyre fine....HELP!!!
    i switched out the front brake pads 4000 miles ago...could the rears be throwing the light on?
    Veteran Member Two Rings 0000_a4's Avatar
    Aug 03 2004
    Chi-Town
    Re: Help!!! abs+brake light
    It could be the abs module. Get it vag.
    K04|Custom FMIC|310cc Injector|GIAC PC-16|APR Inlet Hose|2.5" Scorpion Exhaust Turboback|EVO MS DV|South Bend Stg II Clutch|Unorthodox LFW|18" BBS CH|RS4 Look Front|S4 Rear and Side skirts|Koni Coilovers|A.W.E. Drive Train Stabilizer| 6000k 50w HIDs|Valeo 1 piece Headlights| Stratosphere SS
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    don't worry everyone, i checked.
    the search button DOES still work.
    unfortunately not everyone knows that.
    Registered Member Two Rings CreamAudi's Avatar
    Jun 12 2008
    hempstead,ny
    oits your ABS module, its probabaly shorting to a ground somewhere,but the abs module on are cars are real shotty and they go. So your abs might be heading out mines shot to its 2 289 to replace too
    Cream 98 quattro
    mods
    3MM 20% tint,2 12 jlaudio subwoofers, k04-15,forge 007,Unitronic stage 2+,380cc injectors,18x8.5 asa ar2,rs4 grill,and customized floor mats(adds 25 whp), Infinity Kappa speakers and tweeters, fmic, v-maxx coilovers, custom exhaust, small lip spoiler
    Jan 17 2009
    98 a4 1.8T
    traverse city, mi
    check the wiring from your module to the speed sensor, mine wore through the wires....
    98 1.8T
    Oct 29 2008
    '01 S4, '90 90q20V, '98 A4q
    Virginia
    Common problem. Read this for info on what's goin on:
    www.cheap-abs.com
    check sig and hit me up !
    contact via email please.
