Results 1 to 8 of 8
    Established Member Two Rings Apraudi23's Avatar
    Apr 21 2008
    03 Audi A4 1.8TQ 5 spd
    Stonington, CT
    Turbo Inlet Pipe
    Does anyone know how difficult it is to install one of these it seems like a easy job. I was just wondering if there were any things that might stump me during the install. Thanks
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Re: Turbo Inlet Pipe
    u have to break alot of the one time use clamps on a few hoses so go to autozone and get some.
    Other then that its pretty easy,be careful with the waste gate actuator because its plastic and make sure u get it all the way on the turbo and u will need good 18 inch screw driver to tighten down that clamp.
    if u have any questions just pm me
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Quote Originally Posted by Apraudi23 View Post
    very easy. now depending on which TIP you get, APR for instance missing some nipples that stock and other TIPs have so you have to combine some hoses.
    just look for some DYIs, like K04 installs (i should one have here somewhere, just search under my name), they should also cover the TIP part.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Apr 21 2008
    Stonington, CT
    It is an apr hose. What do mean by adding to it?
    Apr 23 2007
    APR missing one of the little inlets on it. if you bought it new it should have come with an install kit including a T. if not just get a T.
    so you will need to combine 2 of the smaller hoses that go into the TIP into one, since you short one nipple.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Apr 21 2008
    Stonington, CT
    I understand now. Thanks
    Apr 23 2007
    no problem, should be a piece of cake job. just make sure you get all the clamps you need as 03 silverbullet said. also i recommend you make a DIY boost leak tester (check a4mods site for instructions) and check for any leaks after you're done. though you will only be messing around with the vacuum side and not the boost side you still don't want any leaks there.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    You will need to remove the intake lid, and cut a few clamps to get to there. Work on a cool turbo/ engine bay.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
