Results 1 to 28 of 28
    Oct 19 2008
    South Florida
    very frustrated...
    Ok, I'll make a long story short. For the last few months i've been battling against "limp mode" and it would be happening mostly in 5th gear when the car begin's to build boost, all of a sudden I have nothing, no power what's so ever. I would have to pull over and shut the car off and turn it back on just to retrieve power again. I would also get "over boosting" codes. I took it to the dealer and they told me that they needed to replace the cams because the LOBE's were worn. So, I had that done and when i got the car back it drove perfect. A few day's later the same thing happens all over again. I have no clue what to do, here's a list of my mods; APR stage 2, eurocode TP, Apr exhaust, Greddy FMIC, Carbonio Intake and forge DV.
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Re: very frustrated...
    The only code you have is overboost?
    If so, sounds like the n75 valve to me but could be the d.v. or pcv system but that's almost always an underboost code.
    Oct 19 2008
    South Florida
    Yes, there were more codes that led the mechanic to replace my cams, I dont remember them but I do have the invoice in the car I'm sure it's on there.
    DUH! an Audi
    los angeles, CA
    post up codes and see if anyone can help from there.
    Oct 19 2008
    South Florida
    I will first thing in the morning
    Apr 15 2007
    WNC
    were those cams replaced under warranty?!
    2013 RS5, 2014 Q7
    Oct 19 2008
    South Florida
    yes they were
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Fuel pump? Idk man.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Three Rings snosk8tr123's Avatar
    Jan 08 2007
    2007 Audi A4 2.0t
    Orange County
    dude i always go into "limp mode"! soo annoying! usually on hotter days though
    s-line titanium + plate filler + ecs smoked sidemarkers + GIAC 91 octane + Koni Coilovers + e-code test pipe + DMH electronic exhaust cutout + forge dv + bov spacer + tint + LED city light + LED license plate bulb + Yellow PIAA fogs + White Nokya Headlights + European rewiring of lights + Clear corner and blacked out housing + Red LED door lights and foot well lights + debadged + Black audi rings + Light smoke taillights + VMR vent boost gauge + DOPE sticker (+50 whp)
    Oct 19 2008
    South Florida
    Here's the invoice. I don't think it's the fuel pump either, lol.
    Jul 11 2005
    Auburn
    008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
    P2293 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100010
    Fault Priority: 0
    Fault Frequency: 8
    Mileage: 3641 km
    Time Indication: 0
    Date: 2006.06.30
    Time: 08:10:39
    Freeze Frame:
    RPM: 626 /min
    Load: 44.7 %
    Speed: 0.0 km/h
    Temperature: 86.0°C
    Temperature: 45.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 13.716 V
    I wonder if the referenced valve is actually the issue and he only corrected some of the problems with your high pressure fueling system.
    Oct 19 2008
    South Florida
    what else could be the problem?
    Jul 11 2005
    Auburn
    Quote Originally Posted by DTMa42.0t View Post
    http://www.goapr.com/Audi/support/fs...stallation.pdf
    The above document includes the actual TSB the dealership tech is referencing. He followed the oem repair instructions to the letter so no fault to him.
    However, it is possible that in addition to the cam lobe and follower issue you were experiencing that the actual N276 is bad as well. If this is the case, your issue was only partially resolved.
    Do you have a cel now? Can you scan for codes?
    Jan 24 2007
    might your high fuel pressure is going bad. I would take it to the dealer & tell them your having same problem. Also my guess is that dealership doesnt know you have aftermarket mods.
    also does it happen all the time in 5th gear or just when your WOT??
    Oct 19 2008
    South Florida
    I do have cel now ill scan it tmw and see what comes up.
    Quote Originally Posted by A4_Joe View Post
    it depends on the gear im in bcuz WOT in 1st or 2nd sometimes feel's fine and sometimes it feels like there's no boost. The dealership is FULLY aware of all my mods, I do need to go back.
    Veteran Member Four Rings TinaTbolt's Avatar
    Sep 17 2007
    2012 C7 A7 & 2015 Q5 TDI
    San Diego
    oh man, the same shit happened to me...
    I know this makes no sense, but im going to take a bite and say it anyways. i had an Ecode TP in my car when the limp mode used to happen (i noticed the other people in this thread that were complaining of the same problem have the Ecode TP installed as well) the dealership (my friends work there) told me to take the TP out if they were going to do with work under warranty... i took the TP out... and i got no more limp mode. audi couldn't even figure out what was wrong with my car. all they did was change a damn filter... is there a way that the TP could be connected to this "limp mode" because it hasn't even happened once in the last month since ive pulled it out....
    Mar 18 2007
    ditch your APR
    APR 100 Oct / Ecode Testpipe/ Forge DV/H&R Springs/Kerscher CF Splitter/
    Apr 15 2007
    WNC
    or get a fuel pump?
    2013 RS5, 2014 Q7
    Oct 19 2008
    South Florida
    Ive been reading thread's from some1 on the forums named Ih8OEM and he seemed to have similar problems, he went to REVO and his issues went away. I was conned into thinking it was my DV that went out and I ended up buying the upgraded one from FORGE and i still have the same problem, and my stock DV was perfectly fine. I want to make sure that it would be fuel pump issues b4 i buy it.
    Quote Originally Posted by tinaalia View Post
    Ive also noticed that after my TP install this started to become more and more progressive but not every1 on here that is running a stage 2 file, is having the same issue. I doubt it's the tp as well. could it be my pcv system?
    Nov 12 2007
    Grand Junction, CO
    Potentially. It seems as tho everyone who has these types of problems on this forum is running APR software....
    Jul 11 2005
    Auburn
    Quote Originally Posted by AudiWxGuy View Post
    Really? I've been unaware of any potential issues with our ecu upgrade.
    Would someone who is experiencing the issue be willing to provide some datalogging for me so I can see what's up?
    Jul 11 2005
    Auburn
    Quote Originally Posted by Types Cnversion View Post
    ditch your APR
    Do you have the same issue?
    Nov 12 2007
    Grand Junction, CO
    Quote Originally Posted by Keith@APR View Post
    Yeh..I'm not saying it is..It's just whenever someone has a problem like this, it has been with APR software. Probably just a coincidence tho.
    Jul 11 2005
    Auburn
    Yeah, which makes sense as we've more than likely got more installations than anyone else. but I am here to help so I do want to make sure.
    Oct 19 2008
    South Florida
    I'm going to audi monday morning I already to spoke to them and made an apointment. Other then me saying I'm having the same problems is there something specific I can tell them to look into? or let them work there magic( I hope). I really need this fixed the last thing I want to do is part out my car and call it quits.
    Sep 17 2007
    San Diego
    i have GIAC
    Jun 05 2007
    Phillips Ranch, CA
    ^ u have S-chip, or X-chip?.
    I Have been chipped with X-chip for 2 years and barely started to go into limp mode the past 2~3 months because of the cam lobe and fuel pump that I got checked out. I replaced them both with a HPFP and a new OEM cam lobe, now my car performs just like it did when I first got chipped...All better now.
    Then again I have never put in a TP but I am now running the Milltek Hi-FLow Cat.
    Nov 12 2007
    Grand Junction, CO
    i have GIAC
    I see. I have read that people with test pipes also seem to experience problems like this. Do what Acidrome did and have those parts checked out.
