Thread: Hood release
    Veteran Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    Hood release
    They hood release lever in the car will not release the black piece to "full open" the hood.
    Anyone have a clue how i could solve this problem? My guess is i will have to take off the grill or pick it from underneath but i don't know. thanks in advance
    I have disconnected the part below the steering wheel to inspect and the "hook" is still attached to the lever.
    SOLD Silver 01.5 S4 ; VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Registered Member Two Rings
    Jun 04 2008
    MA
    Re: Hood release
    Mine did this same thing a few weeks ago when it started getting cold here.. It took a while to get it to open but when it did open I sprayed some wd-40 on the upper latch and spring attached to the hood. Worked it a bit and everythings been fine since. The grease gets tough in the cold is my thoughts.. Hope that helps!
    Oct 03 2008
    Reading, PA
    Re: Hood release
    Tried this and no luck. Anybody have any other thoughts?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Hood release
    If you can't open your hood you are going to have to pop the latch from under the car. You need a long thin piece of metal and you have to push up on the edge of the latch. It's best if while you are under there call a buddy with a S4 and have them tell you what the part looks like. That way you push on the right part. It takes a little effort but shouldn't be that hard.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    md
    Re: Hood release
    Quote Originally Posted by DanS4 View Post
    Just go back to the cable underneath the steering that releases the hood latch, disconnect the hook from the lever and then you pull on the cable with a pair of pliers, this will release the hood latch up front.. the cable sometimes sctreches over time ..
