Results 1 to 9 of 9
    Veteran Member Three Rings braker15's Avatar
    Nov 15 2008
    2000 S4 Nogaro Blue
    S.Florida
    Wink fuel pump question
    hey, guys i just put in my new fuel pump car runs now, got "ripped off" at the stealer for $262. Now i can hear the fuel pump run, its pretty noisy is that normal? Also do i need to get a new filter? thnaks.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Re: fuel pump question
    Yes. If you're changing the fuel pump, also change out the filter. What you're hearing is the strain of the fuel pump due to a clogged filter. If the filter is not changed, you will burn out the fuel pump and have to replace it again. Get this done ASAP!
    USP CLUB MEMBER #34
    Nov 16 2010
    RI
    hi all
    this is my first post :) so be nice to me :D
    i didnt want to create new thread.
    so i decided to change my fuel pump cuz making some strange noise.
    question, which one i should buy ?
    pump 1
    or
    pump 2
    2nd pump cheaper but it says without gasket, can i use old gasket? or should i buy 1st ?
    ty
    Senior Member Three Rings 1CleanB6's Avatar
    Oct 17 2010
    03 Dlphn Grey B6 1.8t 5MT Quattro
    Lawrenceville,GA
    ^^ http://catalog.importrp.com/item.wws...DO&weight=2.95
    I just ordered one from here. Price includes entire fuel pump assembly and filter and free shipping. Ive ordered from them often when i had my Acura integra.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    make sure you order the correct pump. FWD and Quattro pumps are DIFFERENT!!!
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Nov 16 2010
    RI
    i have the filter already.
    but i dont get it, what does it mean fuel pump without gasket,
    are they talking about fuel tank cover gasket? does it cost 70$ ?
    cuz that how much different is in price.
    so ? :)
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Hey OP did u change out ur filter and it is still making noise? How many miles are u?
    Mine started after 60k and it was the fuel filter. That is COMMON on here with our cars. Usually the fuel pump just cuts out or u might get a code but for the most part a noisy pump is the fuel filter.
    Mine was good... still is good till I traded up at 110k. So u might have some life left in it still.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Nov 16 2010
    RI
    106k
    i did change filter last week, but noise didnt go out, i took out back seat to see whats going on so its fuel pump making that noise.
    but i dont want to spend 70 bucks more for nothing :)
    Aug 05 2008
    Boston
    Guys I have the same problem on mine it's the whirling sound/vibration underneath the passenger rear seat...does it make sense to go with a high performance fuel pump instead? They seem to be cheaper?
