Results 1 to 9 of 9
    Dec 07 2008
    TX
    shift kit for automatics?
    hey guys, i think this is my first post here...been doing alot of reading, and want to say thanks for all the great info you have here...
    i just bought an 06 A4 Quattro 2.0T with Tip...i'm wondering if there's a shift kit for this car??
    Dec 07 2008
    TX
    Re: shift kit for automatics?
    c'mon ya'll....80 something views, not one response?!?
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Ummm. What's a shift kit?
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Dec 07 2008
    TX
    Quote Originally Posted by Tgr_Clw View Post
    that may just answer my question....
    but in case it doesn't, i believe a shift kit would make the stock auto transmission shift much quicker...
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by RUGERJITSU View Post
    You mean like a software upgrade to make the auto tranny shift faster?
    I don't think there are any available.
    Appearance: OEM+
    Apr 18 2008
    Jacksonville, FL
    there is a company who sells upgraded torque converters and other high-$$ upgrades, but i can't remember the name. i think Ih8OEM is getting some goodies from them.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Veteran Member Four Rings Dangler's Avatar
    shift kits are pretty popular with automatic domestic cars. they reduce shift overlap, which is where the automatic trans, engages two gears at the same time during an up-shift. this provides smoother shifts, but robs power since the clutch packs are slipping. shift kits reduce shift overlap, and create more firm and solid shifts, which also puts less wear on the clutch packs. But the shifts are firm and can create a less comfortable ride and can exploit already weakened transmission components in older transmissions. shift kits can come in the form of mechanical upgrades or electronic upgrades (ECU)
    i think GIAC has software type "shift kits" or as they call it "tip-ship" for the s4, all road and rs6. firms up the shifts and speeds them up, from what i've been told.
    I dont believe that there is a "shift kit" for our car. but there are valve body upgrades from IPT and Level 10. call them up to find out more.
    PRIME MOTORING
    F.T.W.L.T.B.D.W.I.C.T.W
    Dec 07 2008
    TX
    Quote Originally Posted by audinoob06 View Post
    yep, that's what i was wondering about...
    i'll have to research the valve body upgrades from IPT and Level 10 stuff....never heard of those, but then again, i've only had my B7 for a few weeks now!
    thanks again for the info!
    DUH! an Audi
    los angeles, CA
    b5/b6 had a tip chip, which would I assume give you your shift kit you desire. If you want to shift quicker, S mode supposedly makes shifting longer and quicker.
    unless your racing your a4, dont think you need faster shifting (only thing I could imagine it being used for)
    p.s. welcome aboard!
    -randy
