Results 1 to 7 of 7
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    No O2 sensor activity
    I checked all the signals on wires and they are perfectly working.
    But the vag-com does not read any activity (0%).
    Could the ECU be bad???
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: No O2 sensor activity
    Are you getting a "No activity" code or are you actually trying to log the sensors?
    08 S4- Stock SOLD
    Apr 01 2008
    Massachusetts
    there are only half of the voltage should be read.
    on the sensor and the plug connector, and the wires going into ECU read the voltage just fine.
    Veteran Member Three Rings AudiHolicS4's Avatar
    Apr 16 2008
    Pasadena, MD
    Quote Originally Posted by mholme View Post
    what if you are getting a no activity code does that mean they need to be changed because after i did my exhaust i get no activity codes from all four sensors and they were fine before im not sure how brittle they are but i just dont see how they all could have went bad at once plus im getting a low input maf code and i put a new maf on and still same thing havent checked the wires but like i said everything was fine before the downpipes and exhaust were put on....sry for jacking your thread
    2000 Silver S4
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by AudiHolicS4 View Post
    If you got the codes only after the exhaust work, I would think your connections are bad. The rear O2 wiring isn't that long and if the sensors are put further downstream, you can easily damage the wires
    08 S4- Stock SOLD
    Apr 16 2008
    Pasadena, MD
    thanks for the reply but what about the ones upstream how would they just go bad like that
    2000 Silver S4
    Jan 29 2007
    08 S4 00 S4
    MD
    They wouldn't. I'd suspect the same wiring issue. When you removed the downpipes, were the O2's already out? Maybe the wiring got damaged? I always think that if something in the general area of where you last wrenched is suddenly no longer working, it's probably a direct result of the wrenching.
    08 S4- Stock SOLD
