Results 1 to 16 of 16
Thread: Squeaking doors
    Aug 01 2008
    Montenegro
    Squeaking doors
    I previously owned A4 B5 and had problems with all 4 doors squeaking when driving off-road or slowly on uneven terrain. Now, same thing happens to my S4, but a lot less since I have only 50k miles on her.
    Is there a fix for this issue? Does this happen because of the rubber surrounding door openings, or metal to metal sound? Do you the same "problem"?
    And one more question - can I use this DIY to change my transmission mounts?
    Thank you!
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    Re: Squeaking doors
    For the door, I would hit all of the pivot points and any other part that may be suspect to movement with some WD-40 and see if that would work. And iI think you would be ok with that write up. I would just use jack stands to be safe.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    Re: Squeaking doors
    yeah i have to hit my doors with wd-40 one a year or so. i also spray some in all my key holes every 30k miles or so.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Veteran Member Three Rings AWD87's Avatar
    Nov 23 2007
    01 S4
    Midwest
    Re: Squeaking doors
    yeah, get some wd-40. It works like magic
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Squeaking doors
    White lithium grease works as well for a more permanent fix.
    08 S4- Stock SOLD
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Squeaking doors
    Quote Originally Posted by mholme View Post
    even that wears off.
    any lube will work.
    i use liquid wrench. seems to last a long time like the white grease
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: Squeaking doors
    use lithium grease. My doors squeaked when I bought the car about a year ago. Its been sitting outside for the first time and the doors Still don't squeak.
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    Re: Squeaking doors
    careful, WD-40 is not a lubricant, no where on the bottle does is say it is a lubricant. It is simply a water displacer, rust dissolver and mild degreaser which can actually dissolve the grease originally intended to lubricate the door hinges. You're better off with true lubricants such as silicone, teflon, and the lithium product mentioned above. You should also never use WD-40 in locks since it leaves a sticky residue behind and attracts dust which will become gunky after time
    My car is fast
    Jun 02 2007
    Re: Squeaking doors
    point taken
    -Douglas McArthur
    Semper Fi!!!
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Re: Squeaking doors
    Wurth HHS 2000 for the hinges.
    Einzsett Gummi Pflege for the rubber seals
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
    Active Member Four Rings burner799's Avatar
    Oct 14 2006
    Hermosa Beach/PHX AZ
    Re: Squeaking doors
    don't use wd-40 to lubricate you fools. Use it to degrease and clean up the door hinge, then get some kind of grease to lubricate it. Don't use wd-40 on bike chains or anything either.....people spray that stuff in places where it doesn't belong too much
    Ti.Sline: yeah my dads got shit in order
    SkunkonCrunk: i had to pay $300 and fight the city after they sprayed a bike lane on my car
    SkunkonCrunk: i hear ya, i know u guys dont get along but let bigons be bigons, or however u spell it, im at a two year
    Aug 08 2007
    San Francisco, CA
    Re: Squeaking doors
    My driver door was squeaking and I used my brother's lube pen for fishing reels right on the pivots. The thing is pretty cool, it's a clear thick pen with a watery lube and it's fixed with a small tip for precision lubage. It worked like a charm and maybe it's me but it opens and closes smoother-ly. {Jokes} I've got to hit my passenger side door now.
    Anyway, I was a bicycle mechanic for a couple of years and rode BMX for a number of years, WD-40 is NOT to lube ANYTHING! It's to degrease and helps with rust removal and penetrates rust/corrosion. Spraying a metal pivot joint seems to be like a fix but if you poured water in a creaky pivot joint it'll do the same, not make noise but cause side effects not desired in the future.
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    Re: Squeaking doors
    Quote Originally Posted by eWock View Post
    lol
    Veteran Member Three Rings ChumbaWumba's Avatar
    Jun 06 2007
    Re: Squeaking doors
    i lubed up my door hinges with extra grease supplied for my JHM short shifter...got that about a year ago and havent had to regrease it since =)
    Registered Member Two Rings
    Jan 09 2008
    2001.5 s4
    Re: Squeaking doors
    I use the syn clear chain lube from my kawi, freeeeeebie
    Established Member Two Rings jdenicola187's Avatar
    Jun 16 2008
    Vermont
    Re: Squeaking doors
    turn the radio up.
