Results 1 to 33 of 33
    May 11 2008
    Vegas
    Breaks price-quality?
    Will be changing breaks soon so would like to know what would be the best thing for the buck out there? looking to go drilled, slotted..
    Aug 11 2008
    sehg
    Re: Breaks price-quality?
    Quote Originally Posted by QDiver View Post
    http://www.mjmautohaus.com/catalog/contact_us.php
    that website has all the stuff you need to know about performance brake pads and rotors. i ended up putting brembo rotors and hawk hps brake pads as a front set up for my b5 a4 and loving it.
    May 11 2008
    Vegas
    Quote Originally Posted by B5Quattro190 View Post
    I use MJM allllllll the time i was just curious if you guys have any specific breaks in mind that you already came across and liked\disliked
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    brakes
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Hey!!! No Hate crimes Allowed!!!
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    May 11 2008
    Vegas
    Quote Originally Posted by A4 Moda View Post
    lol its fine, its about time i learn some English.. thanks for the correction
    Jun 11 2005
    You can get an OEM upgrade, such as the B5 S4 brakes (bigger clearance required),
    or B6 S4 Brakes.
    Otherwise,
    Stoptech makes a good kit
    Ecs makes great kits that come in different Stages depending on your needs(www.ecstuning.com)
    Alcons
    Of course, Zimmerman factory size upgrades,
    You'll like this
    there's one other company, I think sells Zinc coated rotors. Great stuff, just can't remember the name.
    DBQ. DBA..??
    Nothing's coming up.
    that's it for now
    2003 1.8T
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    i bought these:
    http://cgi.ebay.com/ebaymotors/Audi-...9553QQtcZphoto
    they work very well and look great.
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    or B6 S4 Brakes.
    What do you mean bigger clearance required? If you mean wheels...I installed my B5 S4 brakes tonight on stock sport 17" easy...16" would fit.
    Jun 11 2005
    Quote Originally Posted by J-jizzle View Post
    That's exactly what I mean.
    Offset is extremely important with B5S4 brakes.
    The caliper is wider, so wheels would need a more aggressive offset to compensate for clearance.
    2003 1.8T
    Nov 05 2008
    MO
    Stock S4 brakes
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    stoptech are good for their price
    CT4952
    May 23 2008
    Denver
    Quote Originally Posted by ryannorthcott View Post
    i bought these:
    Do you have photos of these on your car?
    Never seen/heard of that type of brake pads.... how long have you had them and how are they holding up?
    Thanks
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by kwimberly View Post
    brakes
    thank you, enough said
    APR Stage 2/AWE Intake
    Nov 28 2008
    2016 allroad prem+, 1988 911, 2015 Outback, 2019 Trek Domane SL5 Disc, 2021 Trek Émonda SL5
    Seattleish
    Anybody ever used these rotors: http://www.audizine.com/forum/showthread.php?t=161124 ? Seems like a solid price for a set of drilled/slotted OEM rotors.
    In short: HLGBGUAHUGLABLAGUHGALGHAGHL
    Current: '08 911 Carrera 4S | '88 911 Carrera
    Past: '16 allroad | '12 MINI Cooper S | '06 A4
    Buncha motorcycles
    Memphis, TN
    ive never heard a complaint about adam's products
    Dec 06 2007
    i bought these:
    glad u like them have nearly the same things i like them, and they're cheap.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    i need front brakes as well....
    is it true with our cars you cant resurface rotors, you need to replace them?
    and should i just do all brakes, front and rear at the same time???
    B8.5 S-line prestige
    #fourringarmy
    Jul 10 2008
    Kelowna BC
    Quote Originally Posted by turboSpartan View Post
    Thanks
    check out my thread on them:
    http://www.audizine.com/forum/showthread.php?t=245657
    Jun 11 2005
    I would recommend everybody to be weary when considering Ceramic pads.
    They aren't they are chocked up to be. They squeal uncontrollably, even with stop squeak gel applied twice on the back of the pads. Rebedding does almost nothing to compensate for squeals. Finally, brake dust is probably even more apparent in ceramics than they are in the OEM compound.
    I would honestly stick with OEM compound for DD. If you see some track time, HPS or HP+ by Hawks are very good sets of brake pads.
    FWIW.
    I got the B5 S4
    PBR CERAMIC pads from ECS tuning.
    Lords alive, all the problems I stated above and more.
    I'm not undermining ECS as they are a reputable company, and I've purchased products from them that range from maintenance, to performance and beyond. I'm saying that PBR isn't a great choice when it comes to ceramic pads for our cars.
    People using the A4 PBR Ceramics have similar experiences.
    2003 1.8T
    Feb 26 2008
    none
    BALTIMORE
    just ordered zimmerman front rotors(vented/drilled) and hawk hsp pads. good deal, $229 shipped for the combo. Just hope they work out, and ship fast.
    anyone have any reviews or thoughts on the set up?
    #fourringarmy
    Jun 11 2005
    you can't wrong with that setup.
    2003 1.8T
    May 21 2007
    Florida
    what break are you changing? your lunch break?
    ohhh you mean brakes! hawk pads FTW!
    2018 Navarro Blue Q5
    Feb 26 2008
    none
    BALTIMORE
    just recieved my pads and rotors from mjm autohause.
    when i get them installed( hopefully soon!!) i will try and get some pics and give a review of the setup
    #fourringarmy
    Feb 26 2008
    none
    BALTIMORE
    i will try and get some pics of what they look like installed,
    review time. install was easy(if you have done brakes before) product quality is spot on, pads were perfect and all hardware was included. braking is smooth, quite, and much quicker then what stock was.
    I would recommend this combo to anyone that is looking to upgrade when their stock ones are gone.
    #fourringarmy
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    sounds like a good choice then.
    Anyone know where to ge b5 s4 breaks besides the classifieds? Ive searched a bit but came out empty handed.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Craigslist out here in Colorado often has a B5 S4 brake setup available. That's my best recommendation other than AZ to find a used set. Also check out audiforums.com and vwvortex.com
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by numer24 View Post
    GD, can you still not spell effing BRAKES!!!!!!!!!!
    Veteran Member Four Rings MJM Autohaus's Avatar
    Dec 20 2005
    Many VAG toys!
    T E X A S
    Quote Originally Posted by Mr.Audi View Post
    Great to hear! We appreciate your business, fellas!
    We feel like we have the absolute best deals with FREE SHIPPING on OEM (ATE) rotors, along with Hawk, Mintex, and OEM pads. When it comes to rotors, we will never be one of those companies that will list an item as an "OEM" rotor when in fact it's cheap Asian made with a quality significantly less than OEM. Warping rotors is no fun. When we tell you that the rotors are "OEM", they will never come in a plain box in an effort to put the blinders over your eyes - they will come in an OEM ATE (German) box.
    When it comes to friction, we're married to Hawk and run them on our own in-house cars here. On deals for Hawk pads by themselves and without rotors, feel free to contact me for Audizine Member pricing.
    : MJM Autohaus :: 210.DUB.PART (382.7278) :: AIM - mjmautohaus :
    Warehouse Distributors for APR | Sparco | MOMO | Eibach | StopTech
    .....and wholesale prices on OEM and maintenance parts for your Audi, too!
    Jan 16 2007
    Wetzlar
    ATE Premium One (coated and slotted by ATE) rotors and your fav. pads.
    Senior Member Three Rings Agro's Avatar
    Dec 11 2006
    04 A4 1.8T USP FWD 5sp
    San Diego, CA
    i bought these:
    I bought these on your recommendation before. I've had them in about 2-3 weeks and am very happy so far. No squeeking, little to no dust, break well in the rain and the price is right.
    APR K04 | APR Turbo Inlet Hose | ER Sport FMIC | TT225 386cc | Neuspeed Snubmount | VMR B7 RS4 Replica's | Forge 007PA DV | Podi Electric Stepper Boost Gauage | Stern Adjustable Front Upper Control Arms | Valentine 1 Radar Detector | Pioneer AVIC-Z140BH Navigation
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by Agro View Post
    amazing, after several posts in this very thread people are still braking their breaks... go figure
    Mar 01 2007
    Bellevue, Wa
    I have been using SPP "Adam's brakes" for about a year now and they have worked great and look amazing as well.
    I looked all over for Hawk hps's but ended up going with PBR's metal master's in the rear and PBR ceramic's for my front B5s4's and they have been great. The ceramic's do dust alot more than the metal master's. I haven't had any problems with squeeling. My advice is to make sure you put anti-squeal on the pads if you want to ensure they don't squeel.
    AZ Addict
    2003 1.8t Quattro 5 speed
    Mod List --= EuroGear Boser CF Hood, APR Stage 1+, APR R1, APR Snub, Magnaflow 16601 Exhaust, B5S4 Brake Upgrade w/SPP Dimpled & Slotted Rotors =--
