Results 1 to 22 of 22
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    coil pack question
    my coils finally blew , would it matter if i went to a VW dealership to pick up replacement coil packs?
    if i walked in asking for revision R coil packs would they know what i was talking about or would i have to travel all the way to an audi dealership?
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: coil pack question
    they'll have them. VW/Audi share those.
    (All 4 went at once?)
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    thankfully no , maybe 2 or 3. very rough idling and tons of misfiring , very rough.. flashing cel etc etc
    i baby footed the whole way home , the cat was glowing red
    thanks for the info , you've put my worries at ease
    2006 600RR
    my photos
    May 03 2008
    Orlando
    I'd take the bus to go get them!
    Kevin W.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    yea u really should drive the car at alll
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    ^ yeah , i'll probably hitch a ride from a friend. siiiiiiiiiigh i was out shopping when they blew
    correct me if i'm wrong , bad coil packs = excess fuel dumped into cats being ignited = red hot cats
    2006 600RR
    my photos
    May 03 2008
    Orlando
    Quote Originally Posted by FireWire View Post
    Correct. How far did you drive? Based on what I learned from a post by Old Guy, you could have destroyed your cat - 50 miles could so it. Be on the lookout for a CEL with a PO420 code.
    Kevin W.
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Quote Originally Posted by kwimberly View Post
    I can precisely say 11 miles. they blew on the way home , first time i checked they were red like if you were to run your turbos pretty hard. second time i checked they weren't lit.
    i have a cel for a small vacuum leak somewhere , I'll definitely keep an look out for that code. are there any physical signs of a bad cat? such as smoke?
    2006 600RR
    my photos
    Established Member Two Rings afozzie40's Avatar
    Oct 21 2008
    B6 A4 1.8T
    Boulder, Colorado
    order the new coils online from ECS. they are the better ones and they are a LOT cheaper, just ordered a set of 4 for 113 and from the dealer they are between 45 and 65 EACH! If you're not in a huge hurry look into it
    03 B6 MT Sport suspension 15% Tint Custom Magnaflow exhaust K&N Stock Air Box Mod ECS Snub
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    i'd like to , but my a4 is a DD so i need her up and running as soon as possible. VW is usually a lot cheaper then the audi dealers. thanks for the tip though
    2006 600RR
    my photos
    Established Member Two Rings Nilya's Avatar
    Aug 19 2008
    2004 A4 1.8T
    BRAMPTON, CANADA
    My coilpack blew had flashing engine lights rumbling engine and misfiring and was driving it for 3 days. When I took it to H2 sport the mechanic said I was very lucky the cat didn't blow on me. When it was diagnose number 2 and 3 were misfiring. I changed my sparkplugs, 2 coilpack and an oil change because there were gas in the oil. The cost was $260 with labour and parts.
    2004 AUDI A4 1.8T
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    I got 4 R revisions in my trunk ready after hearing all these stories.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    If you decide to go to a VW dealership to pick up some coilpacks, ask the parts guy to look up the following P/N: 06B 905 115 R.
    Or you can get them from GAP for $22 each.
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    I hear ya , i got my plugs changed about 2 weeks ago they should be okay. oil change is coming up soon.
    whats life without some problems along the way it wasn't all that bad
    thanks for the part number
    2006 600RR
    my photos
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    *update
    bought 4 new revision R type coils , installed the car feels great. very smooth and the throttle response is improved quite a bit.
    $190
    my old ones were bent when i pulled them out
    2006 600RR
    my photos
    Active Member Two Rings uber_boost's Avatar
    Jul 12 2007
    03 Audi A4 1.8t
    Toronto, Ontario, Canada
    Just get the Hitachi Coil pack...i have em and not a single problem
    Jun 03 2007
    california
    *update
    $190
    holy shit... I couldve sold you mine for way cheaper since i havent used them yet.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    your car will small awful, you'll know.....
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by uber_boost View Post
    I ran Hitachis for almost 6 months.
    Went back to the OEM 'R' coils.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Jul 12 2007
    03 Audi A4 1.8t
    how come???
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    how come???
    My car ran too rich, was slower to rev and I lost about 40-70km per gas tank.
    On the plus side the 'E' coils do feel smoother.
    Appearance: OEM+
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Thanks for the GAP site, im gonna bookmark that for when i buy some new coils!
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
