Results 1 to 40 of 41
    Registered Member Two Rings
    Nov 15 2008
    2005 S4 6spd, Suzuki B-KING
    Chicago Burbs
    Stock clutch how long til they go?
    whos got the highest miles on the forums... lets hear it.
    Don-
    Don-
    Light Silver/Blk 2005 B6 S4 Six spd every option - Carbon Fiber - LM25's on stockers - Ruger R10 19's - Falken 452's 235-35-19's - Milltek Non Res CB-Magnaflow 14851's Mufflers- X-Pipe - APR DP's - Rs4 Pedals - JHM SSK - Flapper mod - WAITING on JHM LT's
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Stock clutch how long til they go?
    95,000 on my b5 s4!
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    does this apply to everyone? bc i had 158k on my stock clutch, and now about 5k on my stage 5
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    33725 on my 04 S4.
    Jun 01 2008
    Apopka, FL
    it all depends on how you treat it, just like any other normal wear and tear item.
    I have 105K on my stock clutch and it holds just fine, but I'll be happy if it lasts another 10-15k after I go Stage II+ though.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    42k miles and two 6k RPM launches at the dragstrip. After the second launch you will get it into 2nd gear, but third gear will not work and the pedal will fall to the floor.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Dec 08 2008
    ^^^ WOW. Guess I will never launch mine.
    I launched my stage 2 STI at the strip about 20 times.(Launch Control - 4200 rpm - 11lbs boost.) I never had a problem like that.
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    I've launched my Southbend FE like 120 times haha
    Nov 15 2008
    Chicago Burbs
    My 05 almost has 40k, and it a was a lease originally before I bought it. In the snow I cant start in second itll die or if traffics rolling 2-5 mph I cant go in first I'll rev match second the car will act like its going to die. Starting in first gear is useless in snow. In deep snow when the tires slip, the clutch will slip too. Plus after driving it for a while if I try going up a hill itll die if I dont ride the clutch. Also I cant rev match, or the clutch will get soft/hot making the trans shift like ass. I must kill the car at least once a day while driving. Being that the car is so quiet I cant hear the engine at all. If I sit close enough so I dont kill it I'm to close to shift or drive normally. Ive smelt a faint burt oil/clutch smell since I bought it after drive the car hard or long. Audi had to fix a bum stock cat, and Audi says the smells the cat trying to burn off still?? Trans/clutch drives great first driving the car after its sat a while. Ill drive to work shift and drive fine the whole way to work, and ill pull in to back the car in and sure enough itl die on me..So Ill have to move the seat closer to back it in. Or Is this normal?
    Don-
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    i have 55000 on my clutch 05 s4 and its getting replaced this week bc its slipping
    daworldisyours.com/forum<----check it out!!!!
    Established Member Two Rings mountainsnbirds's Avatar
    Nov 25 2008
    05' S4 Avant 77' Puch Maxi
    WVU, Morgantown, WV
    76,500 on my B6 Avant. I believe its stock i have only had the car 5 weeks. What are some common symptoms of a clutch going bad on these cars. i know i have replaced clutches on a subaru and an Isuzu trooper. oh and whats a rough cost? i know it was $500 on the Subaru but thats a different story.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    I have 78K on my clutch. A few launches under my belt and no slipping at all... knock on wood its been holding up just fine.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    why are all the B5 guys posting here? Is a B5 now a 4000 pound car and a 4.2L V8 engine?
    Oct 17 2006
    Hockessin, DE
    Quote Originally Posted by sakimano View Post
    hahahahahaha^
    Sep 08 2008
    B7 S4 Avant
    Calgary, AB, Canada
    Quote Originally Posted by beecha91 View Post
    Hey when you are in DEEP snow, and want to get out, turn off traction control if you don't want your clutch to burn.
    What happens is that when you are in a snowbank and try to get out, traction control notices slippage of all the wheels and it tries to brake all wheels, while at the same time you are letting the clutch out and adding gas so as not to stall. All that ends up happening is that the clutch slips like mad and you get that burning smell. Once you turn off traction control you can get out like normal.
    Senior Member Two Rings blkonblkS4's Avatar
    Jun 13 2008
    Providence, RI
    I'll handle this one. Nope, nope it isn't. It also isn't an old a4 1.8t. Just to clarify. Hope this helps everyone!
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    I just hit 50k last night on original clutch, it was a sad day to watch the warranty float away like that. But so far so good, no real slipping or anything I've noticed, but then again, a lot of people said their clutch went out on this forum without having any slipping prior.
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Oct 07 2008
    Milwaukee WI
    The clutch on every S4 I've driven, including mine, is kinda vague and disconnected feeling. Let it out a little too fast with not giving it much gas and it'll die. It seems especially prone in reverse. On the bright side, that's not even remotely a sign of the car needing a new clutch and if anything is a sign that the clutch still has pretty good holding power
    Mar 20 2004
    90' 964, 95' F355, 63' Coupe DeVille
    GV, CO
    Not long if you're supercharged
    Jun 02 2008
    great tip. Something I'd never think of.
    I've owned a couple of Audis (here in Canada) and have never been stuck though, so hopefully that continues! My IS300 on the other hand...yikes.
    Quote Originally Posted by DubSport View Post
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    40,000 on my 04 and ive got slight slippage when agressively shifting otherwise feels great and i hope to get at least 10,000 more.
    Nov 15 2008
    Chicago Burbs
    Quote Originally Posted by Ike View Post
    Thanks! I think if I get a catback it will help with not being to hear the engine rev up like im used too. With Audi trying to make the passenger cabin silent, and noise free it makes it hard to hear how much gas im giving or not giving.
    Don-
    Don-
    In, Out and Around...
    b6/b7 s4 clutch is garbage. ive never driven a car that had a clutch like this before in my life.
    Oct 12 2008
    B9 RS5 B8 S4s, S5
    Saratoga NY
    52,000 on the old clutch and 12 miles on the new clutch. Currently getting a few new gears and syncos put in that were bad and noticed after the clutch was replaced. 04s seem to have a bigger problem than the 05 ans on for some reason. I am the third person I know around here with a new clutch at 50K. I was told you are supposed to change them at 55K.
    My last car was a C5 A6 Tip and that thing gave me tranny problems also.
    Senior Member Three Rings CAA's Avatar
    Oct 26 2008
    2010 Brilliant Black S4
    NoVa
    Quote Originally Posted by iconoclast View Post
    I tend to agree with you. Having said that I have 69k on an '04 S4 and the stock clutch - no slipping so far knock on wood.
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    why do you start in second...you have quattro thats unnecessary.....i dumped my clutch on a hill of about 25 degree slant in the snow, i only got to spin the tires for about 2 seconds, then the car started going up the hill...about three inches of untouched snow
    Quote Originally Posted by CAA View Post
    its my only real gripe with the car... (second would be the whooping sound you get when you drive under 60mph with sunroof open.) however to answer the OP's question... original stock clutch, 46k.
    Nov 15 2008
    Chicago Burbs
    Quote Originally Posted by a4mafia(Red) View Post
    I dont start in second ever cause it will die. Im just used to my mustang hay days where if your driving in rain or snow, and want to drive from a light without losing control you start in second. Its kinda hard to dump your clutch at a light or in traffic, also your driving 2.0T vs the 4.2 I let out the clutch at IDLE with that v8 torque, and it goes no where. We had 6-7 inches of UNTOUCHED snow Tuesday. Wasnt fun at all with those silly P6's. Ordering snow tires today, They changed our lil ice storm warning to another 6-10 inches by mid day friday. Good thing im off Friday...
    Don-
    Don-
    Nov 15 2008
    Chicago Burbs
    I used sold VW's too, and any stick car has that same vagueness to the clutch. I cant tell you how many times I killed cars when I first started selling cars there. Its nice having an easy to operate clutch, but the vagueness sometimes is weird.
    Don-
    Don-
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Don-
    ohh, ok, yeah....thats weird, i can start in second, i dont, i did it by accident once and i got 150 hp vs your beast of a car lol...which makes it even weirder.....good luck with that
    Nov 15 2008
    Chicago Burbs
    Well I could start it in second but requires slipping hell outta the clutch or keeping the rpms up to 3k or so. So I just choose not to now. Im used to V8 rwd cars with no traction, and leaving in second at idle with no issue.
    Don-
    Don-
    Established Member Two Rings s4for5's Avatar
    Feb 19 2005
    05 S4 Dolphin without the Fish Mouth & about every other gas powered toy a guy could want..
    Xenonville
    You guys must suck with a clutch?
    Original owner
    NEVER launched
    94k on Original clutch with NO issues
    (hope I don't jinx myself)
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by blkonblkS4 View Post
    very well put!
    Established Member Two Rings MacTiki's Avatar
    May 01 2008
    Imola 04 S4
    Sacramento Area
    04 S4 43k when my pedal stuck to the floor and wouldn't come up!
    Tiki
    Nov 15 2008
    Chicago Burbs
    Quote Originally Posted by MacTiki View Post
    Tiki
    I hate when that happens
    Don-
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Don-
    Is your clutch slipping that bad or something? If I'm in the flat, I can start in second without getting about 1400 or so at max, and not really even slipping it all that much. If it's even slightly downhill it's even easier than that. I don't really ever do that, but I have so I know it can.
    Just on a side note, did anyone else see the top gear with the vette where he started from a standing start in 6th all the way to it's 155 limiter (I think 5th actually isn't limited to 155, so you can go faster in 5th than in 6th stock, haha, not positive, but believe I heard that) .
    Current: 996TT
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Quote Originally Posted by mountainsnbirds View Post
    Clutch on a 4.2l S4 is about $2,300.00 for a stock unit if a dealer does it.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Dec 06 2005
    SF Bay Area
    05.5 B7 S4
    88k, just had the clutch looked at while having some other work done to the car, it's got about 20% left. Having it replaced now to save on labor costs I'd have to pay to do it later.
    Established Member Two Rings Eteled's Avatar
    May 19 2007
    Cayman GTS
    Santa Fe, NM
    I'm at 59k on the stock clutch.
    Clutch has only slipped once after I was stopped at a red light. That was 300 miles ago! But it hasn't slipped since or displayed any symptoms.
    I'm hoping that it was slipping due to condensation build up as I have been frequenting my local ski resort. It slipped the day after I had been skiing (at the first place I came to a stop at). That gave the car a 32F (16F to 48F) temperature shift in 12 hours.
    empty space
    Veteran Member Three Rings Storm33's Avatar
    May 13 2008
    Cape Coral, FL
    51K on my 2005 B6. I've noticed light slippage intermittently, but overall it just doesn't feel strong. Waiting for the JHM clutch / flywheel combo to come out, and then I'm making the upgrade before I have to deal with the frustration of a breakdown.
    2011 Q7 TDI Prestige S-Line, Orca Black / Black
    2012 Q7 TDI Premium Plus (Sold back to Audi), Mugello Blue / Limestone
    2010 C6.5 S6 Prestige (Guh-bye!), Phantom Black / Black; RS6 Grille
    2009 B8 S5 (R.I.P.), Silver / Black; Nav, Tech, ADS, B&O; MTM Catback, H&R OE, RS5 Grille
    2005 B6 S4 MT6 (Sold), Silver / Black, RS4 Sways
