Results 1 to 11 of 11
Thread: Rotisserie?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Rotisserie?
    Has anybody made one specifically for a B5? I know there's at least one company out there that make prefabbed universal ones.
    I know they're typically for cars needing restoration, but for somebody doing a serious track car build, would it be worth it to add bracing under there? With or without a full cage?
    I guess the question I would have about the bracing is, how much would a B5 benefit from it? What if the owner didn't want a full cage, only a roll bar?
    How much does a fully stripped out B5 unibody weigh? ~1400lbs or less with the subframes installed?
    I can't do it, so I'm curious if somebody else has. Obviously there's a lot of room and commitment involved.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Rotisserie?
    If you are looking for performance than the cage should brace the upper and lower suspension pick up points for all corners. They should be tied to each other and to the chassis itself. That suspension stiffness makes a massive difference.
    The other criteria in a roll bar is occupant safety so that is dealt with according to whatever bylaws or mandates you choose to follow.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Rotisserie?
    as much as I would like to fit into "class xxx" I don't see myself abiding by the rules. At least not until I'm pulling a big enough income to afford it.
    I'm the bastard child that really just wants to build a B/A car that I can waste my money on "Unofficial" track days.
    I understand the purpose of the cage and ideally where some of the mounts go, but it seems that the actual unibody could use some additional reinforcement.
    I've been noticing recently (cold weather) that my A4 will twist going into some parking lots or when the car is "teetering". (opposite corner dampers compressed and the others fully extended). By no means is it near as bad as my T-Top Camaro, but they had cheap/easy fixes, like subframe connectors. If you went to a cage/rollbar later they tied the subframe connectors into the cage. It made it more of an "eggshell" around the passenger compartment.
    cliffnotes: after a cage is installed does the floorboard/unibody become the weakest link?
    Senior Member Three Rings groggy's Avatar
    Oct 20 2004
    Re: Rotisserie?
    it's going to be much cheaper to buy a completed car. You can probably find a completed roller.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Rotisserie?
    Quote Originally Posted by groggy View Post
    If I'm buying another vehicle any time soon (especially a "clean roller") it'll be an E36. In which case it will get a well deserved LSx/T56 swap.
    I guess the direction I'm shooting for (after I learn how to weld) is something that I can track all day and often that I don't have to worry about. It's going to need some help, it has >178K on it.
    NTM we're talking long term. I want to get my new degree rolling before I start worrying about building anything.
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    Re: Rotisserie?
    Hahahahaha.. Rotisserie is in The Netherlands that spinning thing, where you grill your turkey on your BBQ...
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
    Mar 09 2004
    nw michigan.
    Re: Rotisserie?
    Grassroots Motorsports magazine classifieds.
    Jim
    I Do Werk.
    Nov 20 2008
    Harrisburg, PA
    Re: Rotisserie?
    Quote Originally Posted by leon View Post
    That's one definition here in the US too XD, gonna have to google to find how it relates to cars haha.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Rotisserie?
    Quote Originally Posted by DJSticky View Post
    ... Saab Rotisserie:
    Mar 09 2004
    nw michigan.
    Re: Rotisserie?
    That is a pretty sketchy setup. I'd connect the ends and make the bases at least as wide as the car's track width.
    I've got a couple ideas if anyone want to build one of these things.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Rotisserie?
    That's a rather ghetto one, it's the first one I found though. I was browsing the BMW forums and it was on there.
    There's other versions available with height extensions via hydraulic rams, etc. I saw one (MIVE) made of wood, granted a MK2/MK1 is drastically lighter than a B5, but I wasn't real excited about that one.
    I don't understand though, why everybody makes them so long/wide. I understand the need for the legs to go out to the width of the vehicle, but the "snouts" that grab onto the frame/unibody all seem like they're >1' long. If you could slim that up to 4-6" that would decrease the stress on the uprights and pivot/bearing area drastically.
    And yes, I would definitely connect the middle beam.
    I'm curious what the deal is with the rotors on that specific one though. I'm sure you could make a couple rear calipers work via the parking brake lever to be able to hold it in any position you wanted. Presuming the car is relatively balanced around it's axis.
    EDIT: here's the car that's on that Rotisserie BTW
