Results 1 to 7 of 7
    Registered Member Two Rings Sick_Boy's Avatar
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    Why is my car stutting off?
    it happens when i push in the clutch and the r's drop from around 2500-3500 rpms to idle. instead of staying at 800 rs it just drops to 0 rs and of course my car is then moving in to a turn or a stop light while it is shut off. it just happens some times, like once every 5 times i drive it but it seams like it happens more when its cold out. i have been letting it rev down to around 1500 rpms b4 i push in the clutch and i havnt had the problem at that low of rpms just when its at about 2300+ rpms. i have a 01 1.8t and i dont know if i need to recalibrate the Drive by wire or if it is a vac line or what? hopfuly one of you guys know. thanks
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    Re: Why is my car stutting off?
    does anyone know? its like there is nothing there to regulate the idle it just drops to and shut it self off
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Check to see if you have popped on of your intercooler hoses, or maybe your MAF is disconnected accidentally.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    maybe this will help. i ran into the guy who owned my car b4 i did and he said he had the same problem and his mechanic said this part need to be replaced but instead of replacing it he just rigged it so itd work again. so anyone know if this part would be causing my problem?
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    check that black valve that looks like a mini hockey puck with vac lines going through it, sometimes it's half white half black. (it's located in a couple spots in your car and they go bad often so it could possibly be your problem)
    Veteran Member Three Rings audithisworld's Avatar
    Jul 17 2005
    02 coupe quattro 225
    morganville nj
    definitly check around the intake for loose hoses. in my old 2.0 jetta i had the same problem cause a hose kept comin off
    225 ftw!
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Unplug your MAF and see if it goes away...
