Results 1 to 20 of 20
Thread: GIAC 1.5 Chip
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    GIAC 1.5 Chip
    is any one running this " chip " ? it is not a flash it is an actual chip that has to be soldered into the ECU.
    If you are what is there any supporting upgrades that are suppose to be done to the car like injectors and exhaust ? ?
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: GIAC 1.5 Chip
    they make solder on chips for the B6? I thought the B5's were the last A4's they made those for. make sure it's for your car/ECU and not a B5.
    Dec 05 2008
    Re: GIAC 1.5 Chip
    Its already installed in the car ill post a picture in a min im about to take the ecu out.
    When i bought the car there was a plastic box in the glove box said GIAC and had a small chip in it with the Audi rings on it
    Dec 18 2007
    nj
    Re: GIAC 1.5 Chip
    Quote Originally Posted by 03 silverbullet View Post
    cool, wasn't arguing with you, just had never heard of them personally.
    it's likely just a stage 1 flash, but my guess is you will need to contact GIAC to verify exactly what program is on it.
    Good luck, gonna watch this thread since i'm interested in how it turns out.
    Dec 05 2008
    Re: GIAC 1.5 Chip
    oh i know u were not arguing, i called 2 speed shops that were on GIAC's web page that sell there products and they both told me that GIAC didnt make a chip like that. Then i google it and its says they do.
    I emailed GIAC over a week and a half ago with no reply so tech support from them isn't really helping if there is a part number on the chip i will google it.
    The car is flat from idle to 4k then takes off so im trying to find out what else might have to b on the car for it to work right
    Had the car a yr now and only put 3k miles on it because i rode my GSXR most of the year, so now im noticing things with the car.
    Dec 18 2007
    nj
    Re: GIAC 1.5 Chip
    damn you, now i'm dreaming about my old 01 GSXR 750 :(
    Dec 05 2008
    Re: GIAC 1.5 Chip
    im on my second , first one was taken by a geo storm 4 door. bike had 500 miles on it.
    Green means go right , nope only after u finish your cell phone call. . . and yes it was as chick driving
    going to take the ecu out now
    Dec 05 2008
    Re: GIAC 1.5 Chip
    well i got as far as taking the cover off the ECU and didnt need to go any farther the rivets holding the ECU cover on have never been touched.
    Im just gone to assume the car is stock then and the dip shit that traded the car in had some one else's GIAC stuff in the glove box
    Dec 18 2007
    nj
    Re: GIAC 1.5 Chip
    don't know if manuals have a TCU, or if you even have a manual, but make sure your not looking at the tranny computer.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: GIAC 1.5 Chip
    Most likely it was for a ndbw PES T28 kit, GIAC had a 1.5 bar chip for that.
    Dec 05 2008
    Re: GIAC 1.5 Chip
    Quote Originally Posted by widgget View Post
    i was on A4 mods and looked up how to remove the ECU , under the driver side wiper blade.
    Dec 05 2008
    Re: GIAC 1.5 Chip
    do what now ? it was a solder in chip and the ecu cover was not taken off so where did it get put in then ? ?
    Jul 07 2004
    socal
    Re: GIAC 1.5 Chip
    First off GIAC did not use a "solder on" chip. They used a encription board that plugged onto pins that were installed on the ecu board.
    It would look like this.
    The sticker on the top of the chip that is installed onto the board would tell you what file was burned into the chip.
    If the arm holding your ecu still has the rivets on it then your ecu most likely has never been removed to have a chip installed into it.
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Re: GIAC 1.5 Chip
    GIAC was solder chipping up until 2002/03 or thereabouts so there are some 02 B6's with solder chips that never upgraded to the flash chips. This was prior to the release of the 1+ programs however so if your car has a chip that looks like the picture Mike posted then its a stage 1 chip without injector upgrades.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Established Member Two Rings afozzie40's Avatar
    Oct 21 2008
    B6 A4 1.8T
    Boulder, Colorado
    Re: GIAC 1.5 Chip
    some people like to buy those twist off rivet nuts so it looks like its never been tampered with.
    03 B6 MT Sport suspension 15% Tint Custom Magnaflow exhaust K&N Stock Air Box Mod ECS Snub
    Dec 05 2008
    Re: GIAC 1.5 Chip
    thanks every one i will take ecu out of the car and just open the thing up and see if its been changed out its the only way to know for 100%.
    Dec 05 2008
    Re: GIAC 1.5 Chip
    So mystery solved ! I have the GIAC chip that is attached to the board. Pictures are in My Gallery
    The chip reads AWE Bones <- I went to there web page then looked up dealers in the area, One dealer is the one i called about a week ago to ask if GIAC even made this kind of chip and they told me no the next closes was in Delaware
    Chip also has AF28.0BA <- i googled it and got nothing so it might be something that is in the records for who ever put it in.
    The chip also says for Off road use only not sure if thats a legal disclaimer or it has some other settings on it then what a standard 1.5 chip would
    I am also wondering why the ECU cover has a line through it because most junk yards do that so they know it was there part. .. . .
    On to my next problem, why the car just started to over heat on the way home yet no hoses are broke and the VAG - COM pulled no codes so im guessing thermostat
    Sep 01 2004
    Vancouver Canada
    Re: GIAC 1.5 Chip
    You have an GIAC chip installed be AWE and there is likely an installer there that tags his installs with "Bones" the tag is actually AF28.08a ... AF is the ECU code likely and the 08a is the type of encryptor (the board the chip sits in) specific to the 1.8t's.
    Call AWE and talk with them directly.
    Dec 05 2008
    Re: GIAC 1.5 Chip
    i will try to call them tomorrow.
    I been trying to get the GIAC flash loader to work. its on there web page. It will tell me what flash is on there race, pump, valet and something else but i cant get it to read it at all .
    they really didnt have much for trouble shooting steps either
    Dec 05 2008
    Re: GIAC 1.5 Chip
    i called AWE they were not able to tell me what settings are on my chip by what was written on it. They suggested that i call GIAC so i emailed them and requested an upgrade to a new chip with the latest load.
    Ill update this when they get back to me.
