Results 1 to 25 of 25
    Senior Member Three Rings Sunny4's Avatar
    Aug 01 2008
    Mt. Prospect, IL....CHICAGO
    The friggin doors are frozen!! All of them!!
    Okay so I was driving around last Sunday in Chicago/burbs and well waz kinda glad it was 40's and raining rather than below 0 and snowing on my summer tires . When i got home and i opened my door and woosh...a good amount of water trapped between my door and the bottom frame of my car where the S4 emblem is, rushed to the floor. This isnt the first time i noticed this either. Has rained before and water seems to collect in between. No clue why but i dismissed it thinking its no big deal. Well guess what happened?? Woke up today and went to warm up the S4 and my door is frozen !! Oh well i think to my self, its chicago, its winter, and it happens...okay lets just go to the passenger side and open that up...and lo and behold that doors frozen too!! Now im a bit annoyed...ahh wtf, stupid audi's...ur made in germany..im sure it snows out there so this would be a common problem!! wateva...i haven't opened the back doors in a while so there should be no water in between but, today is not my day! Turns out all my friggin doors are frozen !! I mean come ON...well thats my rant! Has anyone else had this issue?? Does water collect between ur door and the s4 emblem? Have all your door been frozen before? Or am I just unlucky on one of the coldest days of the Winter?
    Active Member Three Rings DuncanC's Avatar
    Oct 07 2008
    Visit me on EuroAddiction.net
    Edmonton, AB
    Re: The friggin doors are frozen!! All of them!!
    Yea. The audi seems to let a lot more water in under the doors than either of my Lexus's did. The doors sometimes freeze up a little after a wash but a solid tug has always cured the problem right away. My trunk on the other hand doesn't like the cold. It opens no problem but below about -25C it doesn't like to close constantly.
    Unlucky man that sucks. How long did it take for them to melt?
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    Try some silicone lubricant on your weather stripping. It reconditions it so the rubber won't stick to ice or other junk. Makes it easier to close and open doors.
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    there are little drain slits on the bottom of doors. your drain slits can be clogged with debris. Take a straw or something of that sort and clean them out.
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    vaseline and wd40 ftw
    Veteran Member Three Rings IzzyS4's Avatar
    Feb 12 2008
    B6 S4
    Chicago
    Damn Sunny, that sucks. Only in Chicago will it go from 50 degrees to 9 degrees of freezing rain litterally overnight. I drove home in it too which was pretty scary. Is your car in the garage or outside? If its in your garage get a space heater and let it run in your garage for a little to warm up, if its outside lol good luck since its pretty nasty out. (Snowing!!!)
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    move to socal...
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    so funny
    if you had the vagcom re-code done for automatic windows/sunroof you could gotten in Duke boy style
    In, Out and Around...
    you could just use the key to roll down the window, and then climb in like bo & luke.
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    no problems here today. other than driving on summer tires with 3" of snow on the ground. conti2s suck for winter driving....do not attempt. those conti extremes are my next purchase or a set of winter tires and moving my conti2s to a different rim.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Quote Originally Posted by IzzyS4 View Post
    it went from 55 to 12 last night in upstate new york where I am, so no. I don't think thats unique to chicago.
    Quote Originally Posted by sakimano View Post
    so funny
    and as funny as that is, it would never work. The windows freeze easily. Much easier than it must take to freeze the door.
    I've been in the snow for a while, and I haven't noticed the doors freezing anywhere other than the hinge, which doesn't stop me from getting in. Furthermore, I've never once seen a build-up of water in between the door and the frame...
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Senior Member Two Rings manny6i9's Avatar
    Sep 27 2006
    B8.5 S5
    that is the funniest thing ive heard in a LONG time!
    good thing i live in SoCal
    Aug 01 2008
    Havent had a chance yet. Its been snowing non-stop for a bit now. Finally stopped...gona try the hair dryer first, then jump in thru the windows.
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    i heard when the doors are open, wipe baby oil on the weather strip.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by drew View Post
    move to socal...
    lol! You should also change your name as Sunny doesn't seem to fit.
    All joking aside, clean out your drains.
    Veteran Member Three Rings RocketSurgeon's Avatar
    Dec 17 2008
    CO
    that happens in my F150 from time to time, too
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    I park my Jeep outside sometimes and I really have to yank the door to get it to open. I still dont know why I live here.
    The Audi is taking up garage space and still spring clean. No problems opening the doors in there.
    Also ive never had accumulation of water in the door jams.
    Jun 02 2008
    Quote Originally Posted by sunny4 View Post
    havent Had A Chance Yet. Its Been Snowing Non-stop For A Bit Now. Finally Stopped...gona Try The Hair Dryer First, Then Jump In Thru The Windows.
    Yeeeeeeeeeeeeeeeeeeehaaawwwwwwwwwwwww
    Senior Member Two Rings blkonblkS4's Avatar
    Jun 13 2008
    Providence, RI
    so funny
    His windows were probably frozen shut too.
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    This might work for you...
    Just apply like shoe polish to your rubber door seals.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Senior Member Two Rings ClayFighter's Avatar
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    hahaha... good stuff
    Aug 01 2008
    Haha, well didnt need to use the hot air blower, doors opened up with a bit of a tug the next day. And yup, there was ice in between the door i guess when mother nature decided to give us a break ill be able to get to do some work to fix this issue. And yes the Iorny!! Lol.
    Nov 04 2006
    05 S4
    LI, NY
    yeah so when I first read this thread I thought it was hilarious and impossible at the same time until it happened to me.....last night!!!
    EVERY FREAKIN DOOR!!!!! But I was home and not in any rush. I tried all the doors to see which had the best chance of opening without breaking anything. It was the front passenger door and what I did was used my hand to apply light pressure all around the door frame. And then it opened. I was pushing inwards to help release the froozen seal. And eventually got in. Then I pushed the drivers door open from the inside and I was good. But...be careful. Because 30 minutes later while driving the rear doors defrosted and my rear door open indicators both came on.
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    yep, my doors were frozen shut this morning also.
