Results 1 to 11 of 11
    Established Member Two Rings flatfourone's Avatar
    Aug 16 2007
    2004 A4 1.8T
    Mendon, MA
    Windshield Washers not working!!!
    Hey kids. Can anyone help me out with this? My windshield washers aren't squirting. Yes, I have plenty of fluid. Is there a pump that went out? Is there a fuse I don't know about? Please help me. I beg you.
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Re: Windshield Washers not working!!!
    Last time these did not work on my car, the pump was out.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Veteran Member Three Rings Dos::Avants's Avatar
    May 30 2007
    Garage no more :-(
    'sconsin
    Check fuse #37. Upgrade to 30A.
    Also, click below.
    http://www.audizine.com/forum/showth...r+fuse+upgrade
    Avanta-Humpa-Lot
    Aug 16 2007
    2004 A4 1.8T
    Mendon, MA
    Thanks for your help on this. I didn't realize it was such a common problem. I appreciate the help!
    May 30 2007
    Garage no more :-(
    'sconsin
    kewl
    Avanta-Humpa-Lot
    Senior Member Two Rings 1stb6's Avatar
    Jun 14 2008
    B6 1.8T Q
    Gainesville
    since i threw a 30a in mine.....have had no issues....friggin awsome
    Revo+1, 034 HFC, Techtonics DP, AWE Exhaust, RS4 Sway bar, H&R Coils, AudiUP Snub, HBC..
    Established Member Two Rings audimcnasty's Avatar
    Jul 20 2008
    black B6, white Q5
    chicago
    question...does that fuse control both the headlight & windshield washers?
    ...because my headlight washers work, but my windshield washers don't. it's gotten really cold here, so i figured there was ice buildup in the windshield squirters. i planned on waiting a bit to see if they would work again, but this fuse issue is something i wanna look into. if the fuse controls both, then i'll know it may be something else since one is working for me and one is not...
    - eddiemcnasty
    Forum Moderator Four Rings piaadoll's Avatar
    2000 Grand Jeep Cherokee, 2016 S5
    San Jose, CA
    whoah! so glad i came across this. Mine stopped working too though it's all full!
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Yea either its a fuse, the pump, or their clogged. If they are clogged, taking them off and put a strand of copper wire in the nozzle should do the trick. Worked for me...
    Sep 18 2006
    03 A4, 03 Corvette, 07 HHR.
    Maineville, Ohio
    Replaced fuse # 37. Thanks for the help.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    yeah, fuse is bad
