Results 1 to 40 of 55
Thread: rs4 rear sway
    Veteran Member Four Rings italia8287's Avatar
    Jul 23 2008
    New York
    rs4 rear sway
    is it worth it and where can i pick one up from?
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    Re: rs4 rear sway
    try search AND look up Performance CAFE!
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Apr 15 2007
    WNC
    Re: rs4 rear sway
    thats where I just ordered mine. I hope its a difference I can notice!
    2013 RS5, 2014 Q7
    Registered Member Two Rings Jim@STaSIS's Avatar
    Sep 22 2008
    sonoma, ca
    Re: rs4 rear sway
    you're not putting that on a car w/ stock suspension, are you?
    Nov 12 2007
    Grand Junction, CO
    Re: rs4 rear sway
    It makes a huge difference with the street sports. BTW, Jason, I'll be doing an Autocross in Jan. I'll get some pics to represent that STaSIS suspension.
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Re: rs4 rear sway
    HUGE difference from the rs4 sway bar
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Nov 12 2007
    Grand Junction, CO
    Re: rs4 rear sway
    By huge, he means MASSIVE!
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Re: rs4 rear sway
    Ok so I have the bar on sport suspension how likely am I to blow the endlinks after a lot of hard driving?
    Sep 22 2008
    sonoma, ca
    Re: rs4 rear sway
    actually this is jim from stasis but who's counting. =)
    the rs4 bar is way too much for a stock a4 suspension. different? yes. better? no. you don't have nearly enough tire to deal with the added rate of the rs4 bar. an arb is a spring, it adds spring rate when the car rolls. an rs4 bar on stock suspension is the same as adding rear springs that are 5x stiffer than stock and leaving your front springs the same. how do we all think that would work?
    if you add too much rear spring [giant arb] proportionally, then you'll make the car very tail happy. the rear will not roll enough to get the tires to grip and the back end gets really light and scary. buy yourself springs and dampers, then a bar. it's $ better spent.
    Nov 12 2007
    Grand Junction, CO
    Re: rs4 rear sway
    I don't know why I wrote Jason...I read Jim. Sorry dude.
    Veteran Member Three Rings TwentyValveB5's Avatar
    Sep 17 2005
    2010 R8 V10, C6 Z06, 987.1 Cayman S, E36 M3, 2006 Touareg V8, 1973 914 2.0
    San Diego, CA
    Re: rs4 rear sway
    Quote Originally Posted by Jim@STaSIS View Post
    Then what's your opinion on a matched set like the H-Sports? Obviously a set of Ohlins or even Street Sports would be better, but I'm asking for the budget-conscious ;-)
    Jul 16 2008
    San Francisco
    Re: rs4 rear sway
    I agree but isn't the front sway bar on our cars 29mm, the exact same diameter as the front sway bar on the RS4? Considering that our engines are mounted in front of our front axles and our front sway bars are so thick, I would have to say that the rear RS4 sway bar is a little bit more than just "different".
    Sep 22 2008
    sonoma, ca
    Re: rs4 rear sway
    no worries on the jim/jason thing! he's been here for like 10k years. I'm lucky to be confused for the most knowledgeable audi dude out there.
    we've got a fixed height touring kit [spring + damper] that kills it for the $. call me.
    i'm not sure i get your point. the key here is the proportion of front to rear spring rate. in a front-heavy awd audi the rear bar is proportionally smaller than the front to tune understeer into the car for safety. everything else beign equal, if you change the proportion and make the rear bar larger then you reduce the understeer tendency. BUT if you go to far [a la rs4] then you get sloppy bags of oversteer which is also bad [and way less safe].
    we shoot for neutral with slight understeer bias in our suspensions. if you add a little more bar, things get better. but the 'if some is good TONS must be better' method doesn't apply here.
    better to first address the root issue - the stock suspension is to soft.
    Sep 22 2008
    sonoma, ca
    Re: rs4 rear sway
    sorry i didn't read this right. the hsports are great, they are both larger than stock but keep the ratio right. you'll get a better result for the $ by changing the springs + dampers than adding a f+r bars to a stock suspension. we really like the b7 with our rear bar [22mm], stock front bar with springs / dampers. it's magic.
    Quote Originally Posted by TwentyValveB5 View Post
    Jul 16 2008
    San Francisco
    Re: rs4 rear sway
    Well I personally think that oversteer is safer.
    I just don't like the idea of understeering off a cliff on a canyon run =)
    And is the sline suspension too soft as well?
    Honestly I have no complaints on how the car handles right now, I'm just worried that it can harm the car.
    Sep 22 2008
    sonoma, ca
    Re: rs4 rear sway
    a little oversteer can certainly more fun, but also not safer. better to push a little than swap ends.
    the stock suspension is great for what it's designed to do. go fast around corners was not top of the priority list. if it is, then yes. spring rates need to go up and dampers need to suit them. remember - the giant rear bar you bolted on is just a rear spring.
    that said, i don't think it will hurt the car - the endlink is the weak link and you will likely see higher failure rates since the part is more highly stressed.
    Jul 16 2008
    San Francisco
    Re: rs4 rear sway
    Are there stronger rs4 end links?
    Jul 23 2008
    New York
    Re: rs4 rear sway
    alright thanks guys so i guess its a no go on the rs4 sway until i get some more suspension work done.
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Nov 12 2007
    Grand Junction, CO
    Re: rs4 rear sway
    The sway+coils+taking turns at 80=fun!
    Apr 15 2007
    WNC
    Re: rs4 rear sway
    I feel like a LOT of people on these forums have sport suspension and rs4 sways with good results?! Am I wrong? I didnt think so many people had coils.
    2013 RS5, 2014 Q7
    Jul 23 2008
    New York
    Re: rs4 rear sway
    Quote Originally Posted by rnp614 View Post
    i was under this impression too.
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Jul 16 2008
    San Francisco
    Re: rs4 rear sway
    They do, because they are not happy with the current ratio/setup of the stock sway bars. Honestly, I don't feel that even with the RS4 rear its that easy to have oversteer. The only time I was able to do it was in the rain, making a u-turn with tc off where I tried to get it to swing out, and I had to perfect the technique too, most of the time the car would grab perfectly, just like I wanted it to.
    Apr 15 2007
    WNC
    Re: rs4 rear sway
    Good to hear.
    2013 RS5, 2014 Q7
    Registered Member Two Rings 08 B7's Avatar
    Oct 30 2008
    YONKERS NY
    Re: rs4 rear sway
    would the rs4 sways work good with oem sport suspension?
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Re: rs4 rear sway
    Quote Originally Posted by 08 B7 View Post
    LOL look at the above post...Its explained...unless your lowering your car from stock, Sway bars dont do much, prob create a lil less roll but unless ur stock shocks are stiff ull get body roll ur matter what...
    Get Coils, then RSB...world of difference...FSB idk about
    Veteran Member Four Rings Great White's Avatar
    Oct 07 2008
    Pinarello Prince w/Record 10sp
    Raleigh, NC
    Re: rs4 rear sway
    Quote Originally Posted by 06B7audiA4 View Post
    I was under the impression that Jim was referring to the "oem a4 suspension" not the "oem a4 sport suspension" I believe they are two different settings.
    What would you say Jim?
    Nov 12 2007
    Grand Junction, CO
    Re: rs4 rear sway
    all oem is not meant for sway
    Senior Member Three Rings MichiganAudiDvr's Avatar
    Nov 19 2008
    2007 Audi S4; 2007 Chevrolet Tahoe LTZ
    MI
    Re: rs4 rear sway
    I run stock (non-sport) suspension on my 2006 A4 with the RS4 rear sway bar, snub, APR 93. I feel that the bar really cleaned things up, especially on highway ramps.
    Noticeably less understeer (which to me is harder to control/correct than an oversteer situation, even though some say it is unsafe). Despite my crazy thick RS4 bar, I have never been able to create an oversteer problem with this car. So, no worries. I would do it if you are looking for an inexpensive quick improvement.
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Re: rs4 rear sway
    ^^^ I agree. I had the RS4 rear sway with stock sport suspension for about a month before upgrading to coilovers. Before the rear sway, the car had loads of understeer. After having it installed the car still had some understeer and the only time I oversteered was on an off camber onramp in the rain. I agree that too much bar in the back will produce unwanted oversteer, but in my experiences the RS4 rear bar is no where near being too much bar. I think it brings the car closer to being neutral but still doesn't jump the line over to giving you oversteer with the sport suspension and stock Pirelli P6's.
    And to further continue the debate... I always lived by the motto "oversteer scares the passengers while understeer scares the driver." I feel way safer getting sideways because you can modulate the gas and quattro will pull you out of almost anything. I've been on the skidpad at the track and pulled out of nearly 90 degree slides (video to prove it http://www.youtube.com/watch?v=z5Dbb...e=channel_page Also, with coilovers and a rear sway I still had to use the ebrake to get the rear end out because it would just understeer) Understeering is pretty scary when your wheel is turned and you are plowing straight ahead hoping that your tires regain grip before you crash. I'd definitely rather get sideways because I think it's easier to feel when it's going to happen and then you can react accordingly.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Jul 16 2008
    San Francisco
    Re: rs4 rear sway
    Ok so no one knows of any upgraded endlinks lol? Ecs has some non-oem ones for like $40 a pop. Anyone ever try these?
    Nov 12 2007
    Grand Junction, CO
    Re: rs4 rear sway
    do not buy anything from ecs.
    Senior Member Three Rings Kerby's Avatar
    Nov 10 2008
    I park on the street.
    Brooklyn, NY
    Re: rs4 rear sway
    this is no good for stock sport suspension either?
    Soon
    HPF M3
    Gone
    G37S
    B7 A4
    E39 M5
    SC300 TT
    Mar 07 2008
    Audi A4 B7
    VA
    Re: rs4 rear sway
    Quote Originally Posted by Kerby View Post
    As I said a few posts above, and most other people with an RS4 rear sway and stock sport suspension agree...
    Quote Originally Posted by Glassnpowder98
    When driving the car how you would around a track, (braking into the apex and then accelerating at and out of the apex) the car does not oversteer. There is actually still a little bit of understeer if you push it past it's limits, but a lot less understeer than with the stock swaybar. Some people will claim that they can get the rear end out very easily with an RS4 swaybar to induce oversteer. However, in my experiences I would have to do a Scandinavian flick or some other type of rally/drift based manuever to induce oversteer. I am still a big advocate that a rear sway bar is the second best "bang for your buck" mod next to a chip.
    Mar 26 2007
    California
    Re: rs4 rear sway
    Would I benefit from the Rs4 sway? I am running Vogtland coilovers on my 3.2 Quattro.
    thanks in adavance!
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    Re: rs4 rear sway
    He speaks the truth! This kit is a perfect choice for those who are looking for a tasteful drop and a huge increase in handling performance at a great price. I actually just had this kit installed about 2-3 weeks ago, and it has made a world of difference. Not only is the car much more stable thru the twisties, it is an overall improvement in ride quality/comfort as well.
    I even worked with Jim directly, and he definitely knows his stuff. We discussed this very issue at length, and he was saying the same thing; the RS4 sway makes the car very tail-happy, and even with my upgraded dampers/springs I wouldn't want to run the RS4 sway.
    Jul 16 2008
    San Francisco
    Re: rs4 rear sway
    There's not a single person on the b6/b7 with the 22mm sway bar that thinks their car has oversteer without them trying to make it have oversteer.
    B7a4sport have you ever driven an a4 with the sport suspension and an rs4 sway bar? I agree that it normally doesn't make sense to upgrade just the rear sway bar. We did just that on my friends 300zx tt before he installed the front, and that is tail happy. Driving it didn't feel right, it felt very unbalanced and the bar was only 21mm. This is not the case with our cars. Our cars are so unbalanced out of the factory it's retarded. The bar makes the car much more balanced.
    Oct 07 2008
    Raleigh, NC
    Re: rs4 rear sway
    ^ yeah, I find this thread intriguing. All I've read about the RS4 sway on the forums are good things. I do plan to lower the car in teh next month or so, but I just my rear sway installed today. I have the OEM sport suspension... I'll you guys know how it goes :-)
    Feb 29 2008
    Re: rs4 rear sway
    I'd say the definitive reason is that the RS4 sway is by far the most affordable option, and I can't say I'm not going to get one myself.
    I myself have not driven such an A4, Norcal, I was merely confirming that Jim was consistent with what he said in this thread, and what he and I spoke about in-person when I was at Stasis. Those were his recommendations to me, not me saying "I wouldn't want to run an RS4 sway."
    Other brands of rear sways are in the $300 range, while the RS4 can be found for less than $100 in the classifieds at times. I bet the difference in feel is not sufficient to justify up to 3 times the cost, but it all depends on individual preference in the end.
    Sep 22 2008
    sonoma, ca
    Re: rs4 rear sway
    What we found on the b7 [with a professional test driver and several very experienced suspension / chassis engineers that raced b5/b6/b7 chassis cars for a few years] was that on a stock car [i forget if it was an Sline or not] was that the rs4 bar was too stiff for the oe suspension [the 20mm s4 bar was a better match]. Now if you change the spring rates then you can tune them to allow a stiffer rarb, because even though you’ve made the car stiffer all around, you’ve still only increased the r:f ratio slightly over stock. Long story short if you have a stock car change your springs and dampers. There is massive headroom for improvement here. We design the spring rates to take advantage of a larger bar while maintaining a neutral chassis. We run Ohlins SLs on our b7a4 and a 22mm rear bar and it's brilliant. If you’re local come drive it, you’ll see what I mean.
    A little theory: A sway bar is a spring. It allows a suspension designer to add dynamic spring rate when the car rolls, without having to deal with the added ride harshness of always having that stiffness in the spring. What you do by adding rear bar stiffness is decrease rear roll, which decreases rear grip as the suspension isn’t able to load the tire as much [some roll is good, this creates grip. We like grip.]. Thus you increase front tire grip, somewhat artificially, by sacrificing some rear grip. Changing the way the car utilizes f/r grip and biasing it more toward the front [understeer = front tires lose grip, rear tires have grip] will help [this is all very audi-specific, btw] make the car neutral but it’s easy to go too far.
    So if you have stock suspension and an rs4 rear bar you need to do the right thing and call me and buy a STaSIS suspension! =)
    Last edited by Jim@STaSIS; 12-22-2008 at 12:31 PM. Reason: the often tenuous relationship between fingers and brain..
    Oct 07 2008
    Raleigh, NC
    Re: rs4 rear sway
    If possible, I think it would be helpful to find out if it was a s-line or not...it's not like we're not gonna be lowering our cars on way or another
    I'm definitely lower the car in the near future, for now I'm gonna drive my s-line with brand new RS4 sway bar this weekend and see if I can say something intelligent on monday.
