Results 1 to 7 of 7
    Registered User Two Rings john@fifteen52's Avatar
    May 02 2008
    B7 A4, Mk3.5 Cabrio, Mk5 Jetta
    White Plains, MD
    For anyone who has installed the S4 rear valence...
    I understand most with the S4 valence use a dual tip exhaust made for it (AWE, etc). But does anyone know where the OEM single tip would line up in the dual opening? I'd like to convert the single tip exhaust to dual or use a single wide tip on each side, but I need to figure out if I can use a normal Y-split dual tip or if the pipe has to be relocated to the center of the opening. I have a feeling that the single tip would sit more to the outside edge of the dual opening.
    Pics to show the tip position would be great, but that may be asking too much
    Hopefully this is clear and thanks for any insight!
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    Re: For anyone who has installed the S4 rear valence...
    That's exacly what I did. If you try to place a Y split dual tip, it won't be properly alligned. The guy's in charge of the installation need to be experts so that they con change that straight "Y" form into a more curved "Y". I really dont know if I made my self clear enough. I am from Mexico and I am doing my best with the english...
    The thing is, they did it for me, the can do it for you, it´s just no a direct swap.
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    ^are those the vibrant tips? i first had planned the exact same thing but my shop couldnt get the tips to go the way they needed to fit properly for the s4 valence so i scrapped the idea. my car was at the shop for a day and they still couldnt figure it out
    Sep 19 2006
    Mexico
    No, they are a local brand, nothing fancy. I saw the guy who did the job for me working, it can be done but it was a PIA. Lot's of cutting, bending, heating, bending again, etc...
    May 02 2008
    White Plains, MD
    Thanks for the replies and pics! One of the tips I was contemplating has a slightly offset inlet. It may be enough to ease installation a bit. Looks like I'm going to have to pick up an S4 rear to check.
    Established Member Two Rings 1Knight's Avatar
    Sep 19 2008
    05.5 B7 A4 3.2 Quattro
    Daytona Beach, FL
    I did this with my B7. I but a Y-pipe so I could have Quad tips. The single tips fit on the outermost part of the S4 Valance. So all my shop did was chop the single tips created an offset pipe and just welded on the Quad tips....voila!
    B7 A4 3.2 Quattro / Black on Black / 40% Hüper Optik Tint / 18" VMR RS4 Rep Gun Metal Wheels / Blackout Grille / Custom Titanium Trim / Audi Competition Side Badges / Cupra R Front Lip / BB S4 Rear Valance / Quad Tips / De-badged
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    there was a thread on here with a pic of a black a4 with the s4 rear valence that still have the stock exhaust. i think its about a week old. it shows the lineup
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
