Alright so i just got my injectors for my k04 setup and i was sent the wrong injectors. My thing is should i keep the ones they sent me, or send them back and get the ones i origionally ordered.
Bosh: I was sent the bosy by accident. They are the same injectors as the ones found in the 225tt. It came with the install kit which came with 2 spacers and 2 long allen bolts. These are the 225tt injectors.
Seimens: These are the ones that i acutally ordered. they are the sames ones that are on the ECS websight. this is the description.
Siemens injector set works well even for multi-valve heads. These are the best option available for 4cyl engines. Wide-angle single cone with fast response and superb atomization. Compare to TT225 injectors which cost ~$400. Direct fit. Fuel rail spacers not required
The Bosh ones look like the seimens ones also (they are fat at the top)
I liked the siemens injectors beucase they are direct fit. My question is are the bosh ones better/the same as the ones i origionally ordered?
