Results 1 to 16 of 16
    Dec 10 2008
    ESP Button Replacement?
    Like many others, my buttons are all peeling, with ESP and my Headlight knob being the worst. Is there a DIY to replacing these (hopefully with photos) ?
    How much are they to buy and where?
    Nov 28 2008
    2016 allroad prem+, 1988 911, 2015 Outback, 2019 Trek Domane SL5 Disc, 2021 Trek Émonda SL5
    Seattleish
    Re: ESP Button Replacement?
    Esp and headlight buttons are ~$50 on ebay. The trouble is that you should order them by VIN from a reputable vendor, because there has been at least a couple variations on the interior buttons, over time. That is to say, some were colored slightly differently than others. Usually, from a vendor, they're around $100, but there's a fair amount of wiggle room.
    In short: HLGBGUAHUGLABLAGUHGALGHAGHL
    Current: '08 911 Carrera 4S | '88 911 Carrera
    Past: '16 allroad | '12 MINI Cooper S | '06 A4
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    You can get them from the stealership or somewhere like ECS.com, or genuineaudiparts.com. To remove the headlight switch you push it in slightly and turn it a quarter turn to the left IIRC. The ESP button cover pops off with a carefull pry as to not scratch your dash.. good luck.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by qirex View Post
    just purchase a new ESP button...and buy the MRKIV VW button. hard plastic wont ever fade. it will fit with no problems
    Dec 09 2008
    Wisconsin
    The MKIV ESP buttons I had were completely different than what's in my B6...
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Get a Funk button from OEMpl.us
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    ^lol i was just going to suggest that. pretty cool, but they are not the "corner" button like the ESP
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Nov 28 2008
    Seattleish
    Quote Originally Posted by zz2h33 View Post
    They are plug & play for the hazard button, though, right?
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Quote Originally Posted by kevlarcupid View Post
    Negative.
    Jun 11 2004
    Montana
    I got my ESP from ecs for like 30 bucks shipped OEM part.
    It is real easy to change
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by SpacemanSpiff View Post
    im talking about the headlight switch not the ESP....
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    I'm pretty sure the Funk button is a direct swap for esp?
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Quote Originally Posted by sambrody44 View Post
    if you look at the two buttons you can see that the ESP switch is one of the one on the end of the switch bank, because of this the top right corner of the switch is rounded to match the dash. the funk button is one of the middle buttons with four square edges.
    Awesome idea, but it just won't work unless you were to grind down the fun switch and i'm not sure if you could make ti look right.
    Real ESP:
    Funk:
    Dec 10 2008
    Thanks for all the responses!
    Im going to order it from ecs along with the rs4 sway bar.
    So I just pop it out/off with a screw driver or something?
    I don't get the "funk" button, what's the purpose of that?
    Dec 18 2007
    nj
    the funk button is to replace one of the blank areas that does not have a button so that you can add accessories that run off a factory looking switch.
    Dec 18 2007
    nj
    that ESP switch i linked in the photo was only $29.99 shipped on ebay. gonna have to get myself one someday.
