Results 1 to 3 of 3
Thread: water meth DIY?
    Veteran Member Three Rings SummitS4's Avatar
    Sep 19 2006
    2001 audi s4
    Los Gatos
    water meth DIY?
    searched but didnt find anything. does anyone have a diy for the vast water meth? i have seen some horor stories and dont want to install it wrong. thanks in advance.
    2001 nogaro s4 2.8 tial 770's........... 1972 Audi 100ls Bagged
    530 awhp 540 awtq on 91
    Sprint Auto Works / Becausebags
    Rotiform/Airlift
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Re: water meth DIY?
    Its pretty easy. With the Vast kit just look at the picture and that tells you everything you need to know. The drill bit sizes listed are wrong so you will need to make sure to buy the right bit and tap. Use terminal 75 under drivers side kick for power. Good luck, just take your time.
    Elijah
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Re: water meth DIY?
    I wanted to know the same thing...none of you took any pics of the installation? I contacted Vast and they said the kit comes with instructions and they also email you instructions with pictures. Can any post these instructions in this thread? And how long was the install?
