Results 1 to 9 of 9
    Registered Member Two Rings PLzMe's Avatar
    Dec 12 2008
    Australia
    Coolant Runs out Quickly ???? HELP Plz
    Hey guys I seem to sip coolant every few days, but I don't see a leak at all.
    Why is this guys.
    Thanks
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Re: Coolant Runs out Quickly ???? HELP Plz
    Chickity "coolant Flange". its on the back of your engine right under the valve cover... check there.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Dec 12 2008
    Australia
    Mmmm Im sorry but not 100% sure where that is since I don't understand much bout engine work, is there a pic you have you could show me, thanks heaps. .
    Feb 07 2008
    Koeln, Germany
    Probably a leaking coolant block plug. I had this, too. Car would lose coolant slowly, but there was no sign of a leak.
    Audi has a Techincal Service Bulletin out about this problem. Take it to the dealer and it should be a free fix.
    2005 A4 Avant USP 6MT Q
    Senior Member Two Rings 1stb6's Avatar
    Jun 14 2008
    B6 1.8T Q
    Gainesville
    Its BEHIND the engine block....Not the silver piece i circled....just look under that...Its a black plastic piece going into the back of the engine. I JUST replaced mine 2 days ago....a BI@&TH to get out without the right tools...and small hands would help
    oh....and look good...i bet you will have a bunch of white "baked" coolant around there
    Revo+1, 034 HFC, Techtonics DP, AWE Exhaust, RS4 Sway bar, H&R Coils, AudiUP Snub, HBC..
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    look for coolant remains on the top of the transmission, if you see a weird coloration then your flange on the back of the head is leaking. If not that then look under the car from the front and look for that coloration on the oil pan and front of engine which would be coming from the water pump. The pump is behind plastic pieces though so you cant see it. And hope for it to be the flange on back of head because water pump is a much bigger job since the whole front needs to be taken apart.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Dec 12 2008
    Australia
    Thanks guys heaps, ill c how i go if nothing ill take it to audi & c how much they would charge,
    Thanks
    Dec 02 2006
    '90 Subaru Legacy GT 100% JDM
    Wellington, New Zealand
    Even though I'm a complete Audi n00b, but wouldn't the headgasket be the obvious issue.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by i_c_the_light View Post
    its possible, but more likely is the oil cooler
    - Clint
