Results 1 to 4 of 4
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Calling Automatic Transmission Techs (Diagnosticator?)- Clicking noise in reverse
    About 2 weeks ago I picked up a 1997 B5 1.8t FWD Automatic.
    I picked it up for a fantastic price, because the owner thought the transmission was going to explode.
    Here is the problem.
    In DRIVE and or any other manually selected gear the car shifts perfectly fine. But as soon as you come to a stop and put the car in REVERSE the tranny makes a fairly audible ticking/clicking sound.
    I guess what i am wondering is what part inside the transmission has failed. ?
    I have done hours upon hours of research and have came up short for an answer. It seems as though people are baffled when it comes to auto transmissions.
    I have already pulled the transmission and torque conveter out of the car. (BTW, the torque converter/pump and fluid are brand new, from the previous owner)
    Here are the codes:
    5 Faults Found:
    00293 - Multi-function Switch (F125)
    27-00 - Implausible Signal
    00264 - Solenoid Valve 4 (N91):
    Open or Short to Ground
    00266 - Solenoid Valve 5 (N92)
    00268 - Solenoid Valve 6 (N93):
    00270 - Solenoid Valve 7 (N94)
    Any ideas?
    Last edited by absolutegtr; 12-17-2008 at 05:30 PM. Reason: Actual Fault codes edited
    -Sami-
    Aug 26 2005
    Re: Calling Automatic Transmission Techs (Diagnosticator?)- Clicking noise in reverse
    Hey Sami,
    I am investigating the issues that may be invovled, I will get back to you one way or the other, soon.
    Later,
    John
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    Seems like the issue is that you're running shareware. Just register / activate. You'll be fine.
    :D
    Feb 19 2007
    Charleston, SC
    Thanks John, once again I really appreciate your help.
    The more and more research I do, the more I "want" to think it is possibly a failed/failing solenoid(s), in the valve body...or even a possibly bad ribbon cable....?
    And yes, I know need to get rid of the shareware version of vagcom....here are the actual codes (for those who care and for possible future searches):
    5 Faults Found:
    -Sami-
