Results 1 to 8 of 8
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Thumbs up New GT2860RS Logs using Unitronic MAFless file
    Hi guys,
    I just wanted to see what everyone thinks of the log files I just pulled. Mostly looking to see if they look healthy. I think everything is looking pretty damn good but I need a second opinion before I spray some meth and push the timing a little bit.
    CAPs: 5.2 secs
    Lambda:
    Timing:
    Veteran Member Three Rings beejohn's Avatar
    Jan 24 2005
    Pennsylvania
    Re: New GT2860RS Logs using Unitronic MAFless file
    when do you hit full boost? logs look good except just a lil lean, but it seems that's what the tune calls for.
    --beejohn
    2001 A4 1.8TQMS
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    The only reason I would be concerned with pushing more out of that setup is that your IDC hits 91%.
    Not a big issue, but a little more fuel wouldn't be bad. The 13.xx is less than ideal in my mind.
    Other than that I would say that's a respectable tune w/o getting real aggressive. How much boost are you running?
    415 or 440cc injectors?
    EDIT: Was there a big difference between 12/15 "today"(it's 2:35am 12/16 here) and this last thread? http://www.audizine.com/forum/showthread.php?t=251456
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by beejohn View Post
    Hitting full boost by 3,700 - 3,800 RPM.
    Quote Originally Posted by djwimbo View Post
    I'm running 20 psi of boost with 415cc injectors at 4 bar.
    Also, no difference between the two posts. Just figured that the EVAP issue is a more of an annoyance than anything and since I am working with Uni at the moment I thought I would give them a chance to save face and correct the issue for me.
    Should I be concerned with the lean-ness of the tune? I wasn't sure if that was ok since it is in the low 13:1 range prior to me hitting full boost.
    Apr 10 2007
    Eastern PA
    Any other thoughts/comments/input?
    Veteran Member Four Rings SeanF's Avatar
    Sep 13 2004
    Concord (LMS area), NC
    13:1 during spoolup isnt bad.
    dont worry about the IDC, if your gonna run meth, youll have extra fuel.
    2007 Black Mica Mazdaspeed3 GT, w/ navigation
    Built, Blown, and Squeezin' on a 3071r
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    14:1 and 13:1 is normal when first going WOT at low rpms on a BT/BAT. The AFR ramps down from 14:1 at a slower pace on a BT/BAT because the turbo spools up slower then a K03/K04. If the AFR was too rich the car would make less tq and take longer to spool up.
    Apr 10 2007
    Eastern PA
    Thanks for the input Mike & SeanF. I too wasn't sure about the 13.xx prior to hitting full boost.
