Results 1 to 13 of 13
    Apr 15 2007
    WNC
    Question Get spacers off a wheel?
    So I was a bonehead and when I put spacers on for the first time I didnt put any lube in beforehand. When I realized that I had dropped it in to the wheel without lube I tried pulling it out but it had essentially already seized...so i just put em on the car and have driven around 1K miles...
    Now that I've already had 2 fronts go flat, I'm wondering what happens if a rear (wheel wiht spacer) goes flat? How do I get that damn thing off without damaging my wheel? Any tips or tricks? I have a titanium package wheel if this matters.
    2013 RS5, 2014 Q7
    Veteran Member Three Rings Audi Juice's Avatar
    Feb 11 2005
    08 Titanium
    Huntington Beach
    Re: Get spacers off a wheel?
    You are just now learning that it has to be lubed before you put it in?
    Apr 15 2007
    WNC
    Wow, I was wondering how long it'd take for that post to be made. 2 minutes. Not bad. haha
    2013 RS5, 2014 Q7
    Feb 11 2005
    08 Titanium
    Huntington Beach
    You know it! For real though.... You have a rubber mallet?
    Apr 15 2007
    WNC
    No but it looks like I'll have to buy one and keep it with my spare?
    2013 RS5, 2014 Q7
    Sep 13 2008
    Western Chicago Burbs
    wait so you have t put grease all over the spacer before you put it in? i would have never known that. im confused.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    You have to lube a spacer?!??
    Jan 06 2008
    Dacia Sandero
    Arizona
    No, all you have to do is put some grease on the bolts. You dont lube the spacer.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Take a hammer and a screwdriver and tap it off. Then put anti-seize compound on both sides of the spacer. A thin light layer (as indicated on the instructions) will do the trick. Do a search on here.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Jan 06 2008
    Dacia Sandero
    Arizona
    Congratulations, this is the 10,000th time I've been wrong about something!! Looks like you have to put some lube on either side of the spacer to prevent seizing.
    Veteran Member Four Rings Obvis07's Avatar
    Sep 26 2007
    2007 Audi A4
    Irvine, California
    really? i never lubed my spacers before lol. and they come off so easily mmm thats odd.
    Enjoy Life...
    Audi A4 2.0T FWD
    Current Mods:S4 DTM Edition Front Bumper, Black Grill, Black Filler Panel, Custom V2 LED (fly300kts), Iforged RS Equips, Falken FK452, H&R Spacers 5mm & 8mm, Stasis SS, Tint (35%, 5%), LED Interior, Ecode Testpipe, Magnaflow Exhaust
    No more MODs
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    you don't need to lube the spacer. just the bolts the first time i put it on, never since.
    Registered User Two Rings john@fifteen52's Avatar
    May 02 2008
    B7 A4, Mk3.5 Cabrio, Mk5 Jetta
    White Plains, MD
    Quote Originally Posted by rnp614 View Post
    If you're saying that the spacer was stuck to the wheel as soon as you put it on, lube probably would not have helped. Your spacer wasn't "seized" on, it was just stuck due to tight tolerances. If you need to remove the spacer from the wheel, just pop off the center cap and tap it off from the center.
    I would suggest taking a wire brush and cleaning off the inside of the wheel, especially around the hub center. Also clean the hub/rotor surface that the wheel/spacer mates to. Usually a good cleaning during installation will keep parts from seizing over time. A very light coat of anti-seize can be used on the mating parts. Just enough to lubricate the metal, any more will keep the parts from seating properly.
    I've been using spacers/adapters on just about all my cars for the past 10 years or so and have never had a problem with parts seizing. I've only used anti-seize on a few instances where the existing parts were corroded.
