Results 1 to 23 of 23
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    How do you flush the heater core?
    So lately its been dipping below the 0 mark and my heater all the sudden doesn't want to work. It takes for ever to start to blow warm air (20+ min).
    So i checked both the coolant lines to the heater, passenger side is warm/hot and the driver side line is cold.
    First thing i did was open the bleeder on the hard line. Didn't do anything.
    So next step is to back flush the heater core. Can any one elaborate on how exactly to do this? i can get to the driver side easily but the passenger one i can even see where it connects to...
    Is all the coolant going to spill out the engine when i start to disconnect the lines to the heater?
    How do i back flush it?
    TIA
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    Re: How do you flush the heater core?
    Take a look at this: http://www.audizine.com/forum/showth...t=Heater+Flush
    or this: http://www.audizine.com/forum/showth...t=Heater+Flush
    The search feature works pretty well too....
    Nov 25 2007
    First off both the links are the same.
    Second it only half answers one of my three Q's.
    Thanks for your hard work tho.
    Some Go, No show
    Wish List
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    ok....
    Step 1: go to home depot and buy a female hose adapter which would normally be used for a hose repair. It look like this:
    Step 2: go to an auto parts store and buy some heater core hose, which is also pictured. You're not actually going to replace your existing hose, it'll just be for the flush.
    Step 3: Make 2 sections out of the heater core hose, one short and one long. The long peice ideally should be atleast 2 feet long for ease of draining.
    Step 4: Hook up the female adapter to the short hose...
    Step 5: Screw in your garden hose to the other end
    Step 6: Remove both hose clamps and pull off the existing heater core hose where it connects to the firewall. This may be a bitch if you haven't ever removed them just keep working at it though. It might take 2 people.
    Step 7: There will be 2 metal pieces sticking out once the hose is removed. The lower one is the in-flow and the top right is the outflow. Attach the short hose and garden hose to the outflow. Attach the long hose to the in and put the other end in a large bucket.
    Step 8: turn on the hose, lightly at first, and then slowly build up pressure so you don't make your heater core leak into your car.
    Step 9: switch hoses and repeat flush. Repeat until water is clear.
    The other alternative is if you have an air compressor, remove the heater core hoses and spray the air compressor into the outflow. You may want to do both. I did both and the air compressor helped remove stuff even after the water flush.
    Step 10: After the flush, using either method, i would recommend doing a coolant flush as well and bleeding the air from the system. If air gets into the heater core it will also cause heater issues.
    - Justin -
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It shouldn't plug up as it's a constant flow system. If it does, you may have other coolant issues.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 04 2008
    Seattle, Washington
    ^^ yep. My heater worked for a couple days after i did all of that, then due to a coolant leak, air got in the system and what do you know.... heater problems!
    I need to find the source of this leak to figure it out. I'm really hoping it's not in one of my cylinders. Just curious dirtybrd, how much of a repair cost would i be looking at if it were?
    - Justin -
    Mar 21 2006
    Lakeland, FL.
    I have no idea.
    I'm back bitches!
    Jul 04 2008
    Seattle, Washington
    I'm very afraid that i do have a leak in my cylinder because i never see coolant on the ground, but i lose coolant so fast it's retarded. And i'm also very afraid that it's very expensive
    - Justin -
    Dec 19 2007
    York, PA
    whats your oil look like?
    Jul 04 2008
    Seattle, Washington
    ^^ i haven't checked actually.
    - Justin -
    Nov 25 2007
    Thanks for the help
    When i disconnect the heater lines should i be worried about spilling out all my coolant allover my garage floor?
    Some Go, No show
    Wish List
    Jul 04 2008
    Seattle, Washington
    ^^ maybe... when i disconnected mine i just put a painting tray underneath the car just in case. But it's pretty easy once you disconnect the hoses to just make sure they are pointing upwards and then let them rest against the firewall. If they droop down at all they will start to spill. But there isn't really a hole in that section to drain to the ground so you should be ok. Just be prepared with something under the car just incase of a little spillage.
    - Justin -
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    finally going to tackle this...and can't seem to get the hoses loose. any suggestions?
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Nov 25 2007
    channel locks, clamp on to the end (not to tight or you will deform the nipple that the hose is connected to) and give it a twist back and forth. That should loosen her up.
    Some Go, No show
    Wish List
    Nov 25 2007
    Just to add, this never solved my issues. I still to this day have the same problem.
    I'm going to home depot today to make a pressure tester so i can test the coolant system. Ill post back my results.
    Some Go, No show
    Wish List
    Mar 27 2008
    Denver
    Quote Originally Posted by SeatownB6 View Post
    Can't you pull the coils and plugs and shine a light down there and look to see if it's burning in your motor. If the tops of the pistons are clean then your burning coolant.
    Mar 10 2008
    Puyallup
    just got back from my daughters 3rd b-day party...still can't get the bottom hose off. i know i can not put a lot of pressure due to the inlet so i keep pulling, twisting, grunting and nothing just not a lot of space to work and get a good pull
    ps just took out the battery to get more room and still can not budge the hose. i am afraid to put any more pressure on the hose because i don't want to collapse the input feed. i even tried putting an allen wrench between the inlet and hose to loosen things up but nothin'
    Mar 10 2008
    Puyallup
    bump
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by dewey527 View Post
    I apologize for not reading the whole thread but is this the hose you are trying to get off? If so, be sure you remove the metal "U" clip all the way. Then get a long piece of wooden dowel rod. Use the dowel rod and a light hammer to tap downward on the lip to break the connection loose. It will help to file the working end of the dowel rod a little to get a better overlap on the flange.
    Mar 10 2008
    Puyallup
    no problem old guy. it finally came off with enough brute force, twisting with pliers, prying...did the flush and really brown water came out and some sediment, actually put some natural degreaser in and let it sit for 20 minutes flushed about 5 gallons through the system both ways. have heat but only on manual setting when the middle vents are selected. when i use auto it blows luke cold/warm air. so still trying to figure that out. did bleed the system when car was running using the bleeder valve, but didn't help.
    Mar 10 2008
    Puyallup
    the problems continue...had heat for a couple of days then cooler air began blowing. added some coolant, bled the system again and i get heat only sometimes when i use the manual setting. how the hell do you bleed the system to get all the air out or what else is the problem?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    /\ Is there oil in there? Or is that regular dexi-cool the (pink stuff) with a bad camera setting?....It looks brown
    -Sami-
    Mar 10 2008
    Puyallup
    no - iPhone camera and just dirty and the regular pink stuff...fyi i did not flush the whole system but after what i found i probably should.
