Results 1 to 17 of 17
Thread: Whining
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    Whining
    I have a whining noise when I start the car up. Its only when the car is cold. I remember someone else posting this problem but I dont recall what the name of the problem was or I would have searched it by now. I would like to bring it to the dealer so they can fix this asap.
    Thank you
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: Whining
    I had that as well last weekend. Kind of sounds like there is a supercharger around 2k rpms. It disappeared after 3 minutes and hasn't been back yet..
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Three Rings GameBreaker's Avatar
    Mar 19 2008
    Phantom Black S6, GONE but Not forgotten: Dolphin Grey B6 S4
    Chicago
    Re: Whining
    I have the same issue everday I start the car. I know it's not the heat, because I have a heated garage and it's always low 70s in there, the car was serviced not too long ago and I don't have 40k on it yet.
    Senior Member Three Rings dr.evil's Avatar
    Nov 27 2005
    Sparks, NV
    Re: Whining
    Same problem here. Its been there since I bought the car over 15K miles ago. I remember reading that its a tensioner bearing or something like that. Been meaning to dig in there and fix it, but its kinda hard to find the motivation to pull apart the front end when nothing is really broken.
    2014 SQ5 Prestige - Glacier White
    1970 Mustang BOSS 529
    Veteran Member Three Rings s4_fishingbean's Avatar
    Apr 13 2008
    B7 S4
    Ft. Lauderdale
    Re: Whining
    could be low on power steering fluid
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    Re: Whining
    its not a problem.......there has been many people starting threads about this in the past...nothing to be worried about...
    Nov 27 2005
    Sparks, NV
    Re: Whining
    Quote Originally Posted by fitzS4 View Post
    Even if this is the case, I'd still like to know what is causing the noise...
    Veteran Member Three Rings IzzyS4's Avatar
    Feb 12 2008
    B6 S4
    Chicago
    Re: Whining
    The whining is there when I start my car, never really seen it as a major problem.
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    Re: Whining
    it's absolutely normal. my S4 did it when i test drove it at the dealer, and did it through it's entire life time.
    Mar 17 2007
    new york
    Re: Whining
    i dont think anyone has pinpointed it exactly but it could be numerous things.....notting to worry about just keep motoring!!!!
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Re: Whining
    normal for this design. nothing to worry. personally, I like the whining noise.
    Veteran Member Three Rings poopypants's Avatar
    Jun 18 2007
    '64 LeMans, '00 CBR929RR
    Perris, CA
    Re: Whining
    Its the Emmisions pump, or something having to do with the emmisions system. Its normal. If it were a bearing, the whine would not go away, and would actually get worse.
    "The Constitution of most of our states (and of the United States) assert that all power is inherent in the people; that they may exercise it by themselves; that it is their right and duty to be at all times armed."
    - Thomas Jefferson
    Established Member Two Rings CasaS4's Avatar
    Dec 14 2006
    Atlanta, Ga
    Re: Whining
    Quote Originally Posted by poopypants View Post
    Yea, its the secondary air injection pump.
    Senior Member Two Rings khyber's Avatar
    Nov 21 2007
    B6 S4
    Socal
    Re: Whining
    I had a similar whining noise but it ended up being my alternator was slightly loose in the engine bay and it was from the belt. Kind of an odd case though I doubt it happens very often...
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Re: Whining
    Sounds like it's the belt tensioner bearing and it is NOT normal. Mine was fixed under warranty. Lots of posts on this subject.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    Re: Whining
    My S4 whines all the time throughout the rpm range. I thought it was normal after seeing some youtube vids...
    Heres one: 40 sec to 58 sec...
    http://www.youtube.com/watch?v=wghJeKXEiuM
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: Whining
    I've had slight whinning since day 1. I thought it was normal.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
