Results 1 to 24 of 24
    Sep 17 2008
    B7S4
    Ridgefield, CT
    RNS-E and the DIS - not getting RDS info
    Some of you have been following and helping tremendously with my RNS-E install. But I have a new issue and I know at least one other member having this as well.
    When I swapped out the old Symphony unit for the RNS-E, I stopped getting the RDS radio station and song info on the DIS. The RNS-E has the information on it, but the DIS only says the station number, i.e. 104.3. No song and station info.
    I recently VAGcom'd the RNS-E to get the Navigation info on it, which works great, and I know that the current value in Channel 62 is "21".
    Does anyone know what the issue may be? I think I need PetrolDave to help here.
    2006 Silver S4 - Hotchkis RS4 HSport Sways - Euro RNS-E
    Active Member Two Rings Andy's Avatar
    Jul 17 2005
    Calgary, AB, Canada
    Re: RNS-E and the DIS - not getting RDS info
    I was under the impression that you couldn't get song title/info the RDS display with the RNS-E...I could be wrong though.
    2015 S4 Dayton Grey Technik | Sport Diff | ADS | 6MT
    Old: 2014 S4 Brilliant Black Technik / 2012 S4 Ibis White / 2011 S4 Daytona Grey
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Quote Originally Posted by Andy View Post
    I get the RDS on the RNS-E screen but not on the DIS in the center cluster. Im pretty sure others are getting it in the DIS also. Anyone?
    Quote Originally Posted by stretchS4 View Post
    Yeah, I'm having the same problem. I used to have RDS info (station name, song, etc.) display on the DIS. Once I switched out the Bose II to the RNS-E, I lost that functionality. The RDS info only displays when you are in the radio menu. Hopefully there's a way to get it back on the DIS. Any help would be appreciated.
    6MT | Alcantara | 35% Tints
    Sep 28 2006
    A4 Quattro 1.8T
    NY, NY
    same thing happened to me... also the recepton is very bad, does anyone know why such a bad reception?
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Quote Originally Posted by Barela View Post
    Make sure your reception isnt set to "local" in the radio setup.
    Can anyone help us out with the RDS data? Is anyone with an RNS-E getting RDS data in the DIS?
    You have me curious now im going to check it when i get home.
    Alright guys i checked the DIS today for data. I switched to FM radio stations and the station name and number came up on the DIS. As far as song info (band and song), i did not get any of that information.
    Senior Member Three Rings Cyrix9445's Avatar
    Dec 05 2006
    2004 S4, 1995 Wrangler
    Orlando, FL
    It's not possible with the RNS-E to have the song names on the DIS. Kinda sucks that you loose a feature from the symphony to RNS-E upgrade
    2004 Sauce4
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Ok then. Thank you Joey and Cyrix for putting this to bed. At least I won't be chasing ghosts on this one.
    Veteran Member Three Rings charliemike's Avatar
    Jul 24 2008
    Virginia
    This can't be that hard. Probably could be fixed by a new firmware upgrade if Audi was inclined.
    I mean, if I can get song info from the MP3s I play on my RNS-E then it's possible to get RDS too. Right?
    Quote Originally Posted by charliemike View Post
    I would assume so. Its probably a small adjustment that has to be made via coding. Problem is i wouldnt know where to start.
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    What do you mean by "RDS Info"?
    If you are getting the station name shown on the DIS, then that's all the RNS-E will do.
    For some crazy reason Audi didn't include the software in the RNS-E to display other station information (like song titles or programme details) on the DIS, even though the Symphony etc can do that.
    Quote Originally Posted by PetrolDave View Post
    Well and that does it. Silly the songs or details wont show up on the RNS-E. Thanks for the help Dave.
    May 05 2011
    Sunny State, CA
    Is it problem resolved? I just retrofit my to the latest 193 unit from SymII, the RDS is not shown up in the DIS, only the radio freq. but see both in the RNS-E screen. I got the Navigation working on DIS as well. Is it a known problem that Audi removed from the latest firmware?
    Veteran Member Three Rings Porschephd's Avatar
    Jul 11 2012
    2010 V10 R8; 1994 911 3.6 Turbo
    Lenexa, KS
    You won't have the RDS in the DIS. There is nothing wrong with the settings that is a function of the radio. You will only get the station name and number that's it.
    2010 V10 R8 Sepang Blue
    1994 911 3.6 Turbo AWD
    May 05 2011
    Sunny State, CA
    I don't even see the station name, only freq. number in the DIS, but RNS-E screen shows both. Is it a setting to get the station name in the DIS?
    Quote Originally Posted by Porschephd View Post
    Jan 14 2007
    Hampshire, U.K.
    Quote Originally Posted by REV HRD View Post
    Yes, you need to change the value in adaptation channel 62 of the instruments at address 17, see the Ross-Tech Wiki http://wiki.ross-tech.com/wiki/index...8EC/8ED/8HE%29
    Jul 11 2012
    Lenexa, KS
    Sorry I should have been clearer. The station name will appear with XM/sirius only, the frequency will show for FM/AM but the RNS-E will display the RDS for either.
    I know its weird they didn't have it like it was with the Chorus. I think they got lazy with the software...like the Red DIS and the NAV displayed in it. You have to choose your route then shut the unit off and back on to get it to display. At least we don't have that!
    Jan 14 2007
    Hampshire, U.K.
    That must be a "feature" of the US RNS-E software then, as with the EU RNS-E software the station name appears in the DIS if the station is transmitting RDS otherwise you just get the frequency.
    May 05 2011
    Sunny State, CA
    Adaptation Channel 62 currently is set to 21 ( +00001 = Radio (Optional); +00004 = Navigation (Optional); +00016 = Intrument Cluster)
    I guess based on confirmation from Porschephd, the DIS won't get station name from FM in US model :-(
    Jul 11 2012
    Lenexa, KS
    This is what you should see
    May 05 2011
    Sunny State, CA
    You are exactly correct. Just sign up for XM radio confirmed the station name in DIS.
    Jan 14 2007
    Hampshire, U.K.
    I asked this question on audiforum.us - the reply confirmed that old versions of the RNS-E US software did used to display the FM station name in the DIS (as I had remembered) but this was deleted from the newer versions.
    Bad move Audi.
