Results 1 to 8 of 8
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Pistons and rods
    im going bt and everyones saying that ima be going through rods alot. what brand rods and pistons do you guys recomend?
    Dec 06 2007
    Re: Pistons and rods
    JE pistons are good and SCAT rods are not the best but can get the job done
    if u want cheaper source the forged rods and pistons off an AEB motor
    if ur just going to GTRS or GT71R eliminator u don't really need rods only if u go 30 series
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    IE are good rods, or SCAT rods.
    Pistons you have a few choices. JE pistons are great and I used them on my last motor build. A lot of people are using supertech pistons now, i havn't used them before but I havent heard anything bad about them.
    even the mahle stock pistons will work if you staying 1.8
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    im going atp gt71r and mad ppl tellin me im going to need them
    Registered Member Two Rings
    Dec 01 2008
    NM
    Quote Originally Posted by Greek Yayo View Post
    Why are they so mad?
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by sonoflight View Post
    LMAO!
    thinking the same thing.
    also, i like the "ppl tellin me im going to be going through rods a lot"
    that's just hilarious to me. you think after the first time you'd learn.
    but rods and pistons for you are fine. if you really want to push your car a lot, then i would suggest Integrated Engineering rods. they are more than enough for the power you will be making and beyond.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Dec 06 2007
    ^^how much would it run for a shop to do pistons and rods labor wise?
    -Kirk
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    ^ about 800+
