Results 1 to 11 of 11
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    18 deg out, 26k, Fuel pump whirring in the morning.
    Fuel filter?
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    Re: 18 deg out, 26k, Fuel pump whirring in the morning.
    Don't worry too much. Mine did the same thing a couple times last winter, as soon as the car warmed it went away. I thought it was the fuel pump going out or something but it wasn't.
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Only in the morning or consistently throughout the day? If consistently then probably your fuel filter. My car makes all kinds of noises when its cold out ranging from alternator belt to a whistling sound I cant pinpoint.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    If it's a short noise (2-3 seconds) then it's just a pump priming.
    @jdmnomore: whistling sound is probably your secondary air pump. Mine does it around 2500 RPM for a few first shifts.
    Last edited by 40valve; 12-15-2008 at 09:06 PM. Reason: Typed "water pump" instead of "air pump"
    Aug 21 2007
    2007 S4
    Alexandria, VA
    Check your power steering fluid. I had a similar issue, and it was the power steering pump making noise because of a low fluid level.
    Senior Member Three Rings dr.evil's Avatar
    Nov 27 2005
    Sparks, NV
    My car had the same noise as described. Changed the fuel filter, and it went away. Had to get it at the dealer as I guess there are a few styles, and they can get you the right one based on your vin. Not cheap, well as far as fuel filters go. Was about 70 bux for mine. Pretty easy to replace once you figure out the clips (they push in, not pry out) on the fuel lines. Its located under a piece of plastic under the pass. side door.
    2014 SQ5 Prestige - Glacier White
    1970 Mustang BOSS 529
    Mar 11 2008
    Pierceton, Indiana
    Quote Originally Posted by dpbord View Post
    This noise is when i turn the key, not start the car.
    Mar 24 2008
    khgkhg
    Quote Originally Posted by nimski62 View Post
    fuel pump priming
    Account Terminated Two Rings
    Oct 09 2008
    moroblue 04 s4 6sp
    brooklyn
    mine too only when its cold it sound werid for 10 min untill she warms up
    no biggie
    Mar 11 2008
    Pierceton, Indiana
    Quote Originally Posted by 40valve View Post
    fuel pump priming
    Yeah but didn't happen before! thats what concerned me..
    Mar 24 2008
    khgkhg
    Cold does it. Every VAG car I've owned in the past has done it in the cold temperatures.
