Results 1 to 11 of 11
    Veteran Member Three Rings Dos::Avants's Avatar
    May 30 2007
    Garage no more :-(
    'sconsin
    Exclamation stripped thread on oil filter mount
    Changing my filter & oil today, and the f'ing threads on the oil filter mount stripped. My bentley is not working at the moment. What are my options as far as fixing this without having to replace the whole damn cooler?
    Any help or suggestions would be appreciated.
    Thanks.
    Avanta-Humpa-Lot
    Jun 08 2008
    Calgary AB Canada
    Re: stripped thread on oil filter mount
    not alot you can do i dont think.
    if it were the drain plug you could have re-tapped it.
    the cooler is an easy job, but the part is probably $$$
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    The threaded post is a separate piece entirely. Just pull the big nut off from the bottom of the oil cooler then unscrew the threaded post, and screw in a new one.
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by Mike@PureMS View Post
    well thats good news for the OP. how did you strip it anyway? if it doesnt thread, stop twisting!
    APR Stage 2/AWE Intake
    May 30 2007
    Garage no more :-(
    'sconsin
    Hey Guys, thank you for the quick responses. I was not paying attention to the angle at which I was installing my filter, and I think the filter may have not been tapped cleanly. I think the adapter is aluminum and the filter is steel. This is my first time I've stripped that damn thing.
    Any pics available? Like I mentioned earlier, my Bentley on the computer is not functioning properly. Price? DIY assistance?
    Thank you again guys
    Avanta-Humpa-Lot
    May 30 2007
    Garage no more :-(
    'sconsin
    H E R P!
    bump
    Avanta-Humpa-Lot
    May 30 2007
    Garage no more :-(
    'sconsin
    bumpitty bump
    Avanta-Humpa-Lot
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    You're going to need a new threaded insert. It's a pretty much going to be a dealer-only part but I'm guessing is should only be around $25.
    It should be #7 028115721
    May 30 2007
    Garage no more :-(
    'sconsin
    Quote Originally Posted by Splattj View Post
    U B da man!
    Thanks man, I am very grateful for the diagram. Is that ETKA?
    Avanta-Humpa-Lot
    Nov 13 2007
    Gaithersburg, MD
    Nah. It's from www.vagcat.com
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    OP for future information you can call your local dealer and the parts department can look up the part number... believe it or not dealers really don't mark up small parts all that much in my experience.
    Just call, describe the part, have them fax or email you the ETKA diagram, and order. I've done it many, many times in the past. The guys at my dealer are extremely helpful, just give it a chance.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
