Originally Posted by
bassed
Just to clarify how you're coming up with duty cycle. You are logging block 02 and than taking the injector pulse width in ms* RPM / 120000 correct?
Just for shits and giggles I just went out and did a pull it's 61* and 71% humidity and I am running at 81.28% on 630'sat 4bar. I was running 26psi and had a afr of 11.56 at 6890 rpms (looks like I need to go bigger myself to not push it so hard at 30psi). How long ago did you put the walbro in? How many miles? Was it used? Wabro's clearly drop based on data, but with those injectors and with that turbo it just seems stretching it that you're maxing out those injectors just yet. Ever change the fuel filter? What are you putting down BTW? I think you had a build thread a while back, you really should put it in the
Projects/Builds area!!
The 034 IIC software has a datalogging feature that records everything so I was just going off what the ECU was telling me.
The thing is that usually with race gas the tune is a bit leaner 12.0-12.2 and its not unusual to see a point afr drop by just dropping in race gas due to it burning differently so that compensates a bit for the power/boost increase.
I've so far done 2 motor builds and had to pull the motor out 3 times (main bearing girdle/main seal leak) but I just put the Walbro in about 1000 miles ago. The first motor got wrecked due some detonation issues that put some stress fractures in pistons 2,3 and 4 and completely f'd my rings. I was running way too much timing which was the cause of the detonation.
I was running the stock fuel pump for a while which was working out fine but I wanted some peace of mind so I went ahead and ordered up the walbro. I was running the stock pump at 35psi static fuel pressure and running 22lbs of boost. I bought the walbro new from
http://www.autoperformanceengineering.com/
the whole kit with everything was about $120 shipped and the install was a breeze.
I haven't had it dyno'd yet but on my previous engine I was able to stay dead even with my buddys FP Green Evo that made 380whp on a mustang so I would have to assume that its making at least that much if not more now that I'm running more boost and have the tune pretty well dialed in now. I'm waiting until I get some cams/springs/rertainers until I have it dyno'd because I would just have to go back if I were to get it tuned now.
I'll def make a build thread... I'll probably have to make a new thread since all my information is pretty scattered around in all my threads.
