Results 1 to 7 of 7
    Jul 31 2007
    99 Audi A4 2.8 Quattro
    peg city
    heat and flap motor fail
    i have a 99 2.8 and was searching about checking the flap motor causing heating issues?? does anyone know exactly how to check this, or do it with vagcom. I can hear a slight clicking noise, almost like somthing maybe getting stuck? is there anyway to check or clear this??
    Jul 31 2007
    peg city
    Re: heat and flap motor fail
    anyone?
    Jul 31 2007
    peg city
    anyone can tell me how 2 use vagcom to check the flap motor?
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    You dont need a VAG-Com for this. You can do it through the HVAC head unit.
    Check this link out.
    http://www.audiworld.com/tech/int.html
    It will let you control the vents manually and clear any possible blocks. Mine does the same thing, but seems to work if you have no vent selected on the control unit.
    Also - i bet its the potentiometer that is the main issue, that which is telling the motor what position the flap should be in.
    Jul 31 2007
    peg city
    thanks for the reply ima try that tomorrow
    Jul 31 2007
    peg city
    ok so i got a few codes, can anyone help me in how do i solve them!?!
    15.3 Air Flow Flap Motor Potentiometer, sporadic open
    15.7 Air Flow Flap, sporadic block
    22.1 (F118) A/C Refrigerant High Pressure Switch, static open (Compressor remains off until switch closes)
    50.3 ??? cant find what this means???
    anyone help!?!? Im not sure what 2 do?
    Jul 31 2007
    peg city
    does anyone know how to interpret the climate codes?
