Results 1 to 15 of 15
Thread: VAGcom cable ?
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    VAGcom cable ?
    Will this work for the free version of VAGcom for the B6
    http://cgi.ebay.com/ebaymotors/USB-V...QQcmdZViewItem
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Established Member Two Rings svo142010's Avatar
    Oct 24 2008
    2005 Audi A4 1.8
    OKC
    Re: VAGcom cable ?
    Quote Originally Posted by gotboost View Post
    yes
    thats the one i have
    then i upgraded
    Nov 04 2007
    Minnesota
    Re: VAGcom cable ?
    thanks, just bought it..... sick of asking people to run codes:)
    Current:
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    Re: VAGcom cable ?
    thats the one i just bought last week, it works perfectly with my b5 and vag version 311-2 on vista
    Nov 04 2007
    Minnesota
    Re: VAGcom cable ?
    do i just install the software it comes with, and then its ready to use?
    Current:
    Nov 11 2006
    Tri-State
    Re: VAGcom cable ?
    i just downloaded the vag com software from ross-tech.com
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    Re: VAGcom cable ?
    I just got mine last week but, everytime i hook it up it says interface not found.
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Oct 24 2008
    2005 Audi A4 1.8
    OKC
    Re: VAGcom cable ?
    i have another extra vag-com cable and software laying around
    if anyones interested in buying it
    pm me!
    Oct 24 2008
    2005 Audi A4 1.8
    OKC
    Re: VAGcom cable ?
    oh and be careful when you unplug the cable from your car
    my friend separated the plug from the cable
    poorly made cable...
    so just be careful not to just yank the thing out when your done
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: VAGcom cable ?
    Quote Originally Posted by svo142010 View Post
    i leave mine (real ross-tech cable) plugged in all the time and have a active usp extension connected to it, so the whole thing is routed under the dash and just comes up under the passenger seat. and the draw under the seat works great for coiling up the slack and loose end when i'm not using it.
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    Re: VAGcom cable ?
    For those of you having issues with your cable try this out. It worked for me.
    http://www.audizine.com/forum/showthread.php?t=158766
    Drew-
    2013 Audi S4
    Jun 30 2007
    Raleigh, NC
    Re: VAGcom cable ?
    Quote Originally Posted by widgget View Post
    had mine that way (cept in the glove box with my laptop) till the cable crapped out.. i'm about to pick up that ebay cable though.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 18 2007
    nj
    Re: VAGcom cable ?
    i've been thinking about moving it to the glove box since i have my power inverter in there anyway. then both the power for the laptop and the vag cable will be coming from the same location.
    Jun 30 2007
    Raleigh, NC
    Re: VAGcom cable ?
    yeah, if under the seat is easier for you i say go for it - i just got one of those asus eepc's stupid cheap on labor day so i can shove it pretty much anywhere and it fits lol
    The Awesome™
    Dec 18 2007
    nj
    Re: VAGcom cable ?
    i have a really nice dell laptop i use now but would rather it not be in the car all the time and being slammed around. i found some older touch screen laptops on ebay for like $300, so i'm prob gonna grab one of them just to be my vagcom system.
    the touch screen should be much nicer then trying to use a touchpad while driving :P
