Results 1 to 23 of 23
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Angry A New Sound! NOT A GOOD ONE!!!
    UGHHHHH yet again... Here we freaking go.... I think i have taken the car apart now 4 times in the last month. Anyways... I started the car this morning and heard this:
    www.jmlpictures.com/upload/s4/video/sound.mov
    Any ideas before i tear the thing apart again? I can't see anything hitting or rubbing right now which kind of leads me to believe that it's under the timing belt covers :( but i want a second or third opinion. This car is testing me to my limits right now!
    Josh
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Re: A New Sound! NOT A GOOD ONE!!!
    Alternator bearing or power steering pump. It sounds like a bad bearing somewhere IMHO.
    Mar 14 2007
    Phoenix Arizona
    any way of checking it easily?
    Josh
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    take a stethoscope and find where the noise is coming from
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    take the engine belt off then listen then u know for sure if its in the timing belt area
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Mar 14 2007
    Phoenix Arizona
    ok, i will do that. Can you take the belt off w/out removing the core support? (That would be so awesome if you could.
    Josh
    Mar 08 2007
    ct
    ya u can get it off might have to go underneath the car to get it off the lower pulleys its gonna be a pain
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Mar 08 2007
    ct
    or might have to take off couple of other things but maybe not pulling the front off
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Mar 14 2007
    Phoenix Arizona
    ok... well i guess i am going to head out and try and fix this POS again....
    Thanks for the help guys.. i will let you know what i find.. in the mean time any more ideas would be great.
    Josh
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    alternator. enjoy.
    SBSC
    I also like to live dangerously.
    Sep 21 2006
    Norjerz
    Quote Originally Posted by S4-ORCE View Post
    power steering pumps make noises when you turn the wheel.
    SBSC
    Mar 14 2007
    Phoenix Arizona
    why do you say that?
    Josh
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    man, you have no luck with your car! good luck, I hope it gets worked out.
    btw, I don't think its power steering related.
    the homebrew'd s4
    Mar 14 2007
    Phoenix Arizona
    Quote Originally Posted by FrimmelNoJerz View Post
    alternator. enjoy.
    Fun... Well i will be taking the serp belt off and if it doesn't make that noise anymore then that will be the first thing to check... how would i check just the alternator?
    Josh
    Mar 14 2007
    Phoenix Arizona
    It's not the powersteering pump. I went out and started the car and tried turning the wheel and the noise stays the same... it doesn't change at all. Only time the noise changes is if i rev the engine.
    Josh
    Mar 08 2007
    ct
    just take the belt off if u can thats what i would do then just listen
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Mar 14 2007
    Phoenix Arizona
    Ok, i am going to head out right now and do that.
    Josh
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Then its the alternator IMO
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    I'm about 90% sure its your clutch fan hitting your bi-pipe. the mounts for the pipe on the belt cover break easily and it gives the pipe just enough room to hit the fan. if you have a plastic oem pipe, the fan will tear a hole in it, I found that out. I ended up having to buy a APR bi-pipe because of it.
    if its hitting, you won't be able to see the point of contact, so look at the fan blades for damage and feel the bi-pipe with your hand to see if its damaged. if thats it, use a razor blade to trim up the back edge of the blades so it has some clearance
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Mar 14 2007
    Phoenix Arizona
    OK, it's the serpentine belt tensioner pully. It spins a lot and sounds like crap. Alternator sounds fine and spins w/out a noise.
    Josh
    Oh and btw, i took the front end off (or mostly off). Everything is hooked up still but everything is unbolted so i could pull it far enough forward to take the belt off... and i did it in 30 min flat! HAHA So the good thing about all this is a have gotten REALLY good at taking this car apart!
    Mar 08 2007
    ct
    good to hear u found something other than the timing belt
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Mar 14 2007
    Phoenix Arizona
    Yeah me too... i really didn't want to have to take it that far apart.
    Josh
    Mar 14 2007
    Phoenix Arizona
    Can anyone suggest any other parts i should replace while in there?
    Josh
