Results 1 to 2 of 2
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Technical Advice. (rattling)
    Hey guys, yesterday I put in my GSG FMIC. There is now a rattling sound while the engine runs. I checked all clamps and piping first, made sure I didn't leave any tools in there, and checked belts and fans. After checking that last night around midnight, I decided to call it a night.
    In the process of installing the intercooler, I also put in GSG's replacement power steering cooler. This morning I made sure the fluid level is fine, and figured out that the rattling noise stops when I turn the steering to full lock. I checked that there was some oil leaking from my steering rack, (looks to be the motor/pump at the driver side. Does not look like recently leaked oil.. Only thing is, the color of the oil leaked is different from the color of the fluid the dealership sold me.. that i had refilled the system with. Anyways, any ideas?
    Thanks
    2008 Phantom Black TQM
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: Technical Advice. (rattling)
    recheck everything, it's obvious something you might of missed if this issue wasn't apparent before the aftermarket install. If it was late you could of just missed something...
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
