Results 1 to 18 of 18
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Brakes On Fire!!!!!!!!!!!!
    So I pull out from my friends house and release my e-brake and if felt like I was releasing nothing. No spring feel at all it just fell. So I drive 2 blocks away to my other buddys house and I feel something dragging. So I get out smell brakes and see my drivers side rear rotor is literally red hot! I'm pretty sure my e-brake is sticking so how do I get it to let go? Thanks guys!
    High speed Ferrari movement...
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Brakes On Fire!!!!!!!!!!!!
    you can release it by taking it off the caliper in the rear.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Apr 12 2007
    Milwaukee
    go behind the wheel or take off wheel and push the lever up
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    This is a common problem when the cold weather comes, but seeing you live in Miami idk what would cause it to happen to you, but just park your car in gear from now on until you get it fixed.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    look out for warping or damage on the rotors.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Jul 27 2008
    Miami, FL
    I'm still in PA for X-mas so it's very cold up here. Any pic of this lever?
    Apr 12 2007
    Milwaukee
    center black lever
    Sep 23 2006
    Houston TX
    just look at the rear of the caliper where the ebrake line attaches (has a ball on the end), its towards the center of the car. use a rod of some sort to leverage that arm up towards the roof (line pulls down towards ground when engaged and frozen).
    Jul 27 2008
    Miami, FL
    I love AZine. Thanks everyone!
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    make sure you dont set your e-brake after some hard spireted driving. That can cause it to seize to the rotor sometimes
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Veteran Member Three Rings 02B6's Avatar
    Nov 05 2007
    Toronto, Canada
    I broke the spring off last winter. I dont understand, it still engadges and disengadges?
    2002 (B6) 1.8TQM...H&R - S4 Spoiler - 6k HID - open cone filter - Forge Splitter - avic d3 - podi/SW
    Jul 27 2008
    Miami, FL
    All fixed now, I went to pick it up at my buddys house loaded with tools, and just made sure the handle was down and popped it in N and was able to easily roll it. I could see the part that you guys were talking about tho. Weird like thing to break.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    mine freezes all the time in cold weather, so i just leave it in gear.
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Same happend to me, I got it home the next morning and put a space heater on it for 3 hrs and it finally loosened. Frickin sucked...It was just the driverside rear too.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    i never heard of that happening...i live in NJ...and here comes the cold weather
    Feb 20 2007
    ct
    whenever mine do stick when i drive down the road they pop.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    We don't have cold enough weather here, but maybe this will work? Carry one in your trunk? They fire up in less than a second.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Aug 26 2005
    I use a 2X2 ~2 feet long, and lever the ebrake arm on the caliper back opposite the direction the cable pulls, with the stick through the wheel, quick and always works.
