Results 1 to 12 of 12
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    OEM Gallardo Rear Wheel (BBS Cassiopea) On B6 A4 Q
    OEM Gallardo rear wheel
    spec:
    19x11 offset if ET55.3mm.
    the money question is, will it fit a B6 A4 without wide fenders?
    negative rear cambers will be needed for sure I think.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    bringing this thread from a long time ago, however this is a solid question. I just purchased a set of staggered oem Gallardo wheels and would like to be prepared with all the right stuff before i get them so i can mount them up. I already ordered the tires....235/35/19 and 275/30/19 Hankook V12's, now i just need to know what size spacers to run and how the rear wheels are gonna work out.
    Hopefully someone has run this setup, ive seen a few pics here and there of these wheels on B6's that seemed to be oem however its hard to tell if theyre running the staggered setup.
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Jun 14 2005
    Anaheim, CA
    Yikes! That size is pretty aggressive. It'll be sticking out 12mm further than our recommended fitment and you'll lose 52mm of inner clearance. I think you'll need a pretty good spacer to get them to clear on the inside, although I do not know exactly what size would be necessary.
    Brandon @ VMR Wheels
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Quote Originally Posted by VMRWheels View Post
    yep im sure its definitely possible im just trying to avoid fender work.
    i know the front offset is 42, so 10mm spacers for the fronts will be perfect, however with the rears being 19x11's and a 55 offset its gonna be tricky to tell, im thinking maybe a 20 or 25mm spacer
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    In this pic i can tell that the wheels are oem, but i also just realized that they're (4) fronts by looking at the depth of the inner hub where the bolts go in are all the same depth whereas on the rears they sink in much more.
    Senior Member Two Rings Jordan80's Avatar
    Feb 22 2010
    Saratoga, NY
    Old thread but I'm also curious. I just bought 996 twists with a 18x11 rear et 45. What size adapter will I need?
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Quote Originally Posted by Jordan80 View Post
    Got the wheels in, waiting for the spacers, should have these fitted by friday.
    rear tire mounted..
    Veteran Member Four Rings catch's Avatar
    Feb 17 2012
    GTA
    interested to see how these fit
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Quote Originally Posted by catch View Post
    well they didnt fit as good as i hoped, i used a 25mm spacer in the rear which was absolutely necessary to clear (barely) the inner rear shock and fender lining. anyways here are the pics, i didn't even run them, just took some pics of the fitment and took the wheels off.
    overall just took much poke in the rear imo
    Feb 22 2010
    Saratoga, NY
    I think with a little more low and a bit more stretch on the tires you could pull off some really nice fitment and look. Just depends if you're a fan of that look, I think it would look great on that car.
    Also, you said you ran a 25 mm spacer in the rear so your final et was 30 correct? and it cleared your control arms?
    Veteran Member Four Rings audirings4's Avatar
    Nov 23 2011
    SQ7
    DFW
    This guy did it on a B5 a few yrs back.
    Feb 22 2010
    Saratoga, NY
    Yeah too bad he did it with chrome Gallardo rims, would have looked better in a different finish.
