Results 1 to 14 of 14
    Veteran Member Three Rings gotdubd's Avatar
    Sep 28 2006
    Hell.
    "left headlight dipped" ???
    So Im crusing through an intersection thats a little rocky and all of a sudden my MFA displays "left headlight dipped". So I pull over, no dipped light.
    2 seconds later my left headlight flickers on and off.
    Im a little confused. Is this a bulb or a leveling motor issue
    i searched and there wasnt any solid answers anywhere
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    Re: "left headlight dipped" ???
    Def. not the leveller. Most likely the xenon bulb.
    How old are your bulbs?
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Jun 08 2008
    Calgary AB Canada
    could be the bulb going out or a loose connection on the headlight itself
    Sep 28 2006
    Hell.
    original as far as I know
    so nov 2002 when the first owner bought it.
    May 08 2005
    hanover germany
    Your bulbs are going to die. They are quite old.
    It's not the connector which has quite a tight fit. The burn-process gets interrupted by vibrations.
    Sep 28 2006
    Hell.
    I understand that bulbs die. I was making sure before I go spend money on something that I dont need
    May 08 2005
    hanover germany
    You'll be surprised how much brighter the new bulbs will be.
    6 years old xenon bulbs still work??
    Oct 31 2006
    San Antonio, TX
    I'm having the same issue right now. I occassionally get the "left headlamp dipped" warning and I have noticed some flicker from that headlight. Mine are also 6+ years old (Aug 2002). Anybody know how much new xenon bulbs cost?
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    most likely the ignitors, possibly the bulb
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    i keep occasionally getting the "right headlight dipped" warning but i have no flickering or anything. But let's say by the off chance it does start to or the bulb goes out and i want to replace my bulbs, could i replace them with a higher kelvin bulb without having to replace the ballasts and crap too? Cause i'm pretty sure that mine are the stockies as well. I want to upgrade to a 6k bulb.
    - Justin -
    Registered Member One Ring TCleezy's Avatar
    Dec 19 2008
    2005 B7 A4 2.0T FWD
    Texas
    mine are brand new and are flickering still. I occasionally get dipped headlight as well. What should I do?
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    bulb is dying
    Mar 27 2005
    The Cold North
    take connector off from behind the headlight. make sure it is clean and then re-install it. Make sure it is all the way on and properly in place. when i replaced my bulbs my driverside connector was not on perfectly. I thought it was, but it was not. I took it off, cleaned it with electrical connection cleaner and then re-installed it. works fine now. sometimes the connections just get loose or dirty.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Do xenon bulbs go out that fast? I was told that they last the entire life of the car.
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
