Originally Posted by
RAUDY
Guys, I have halogen lamps, so these projectors are already an upgrade.
What I'm wondering is if I have to go HID as well, or can I use halogen bulbs with these projector housings (the DEPO housings are designed for halogen).
I've been using high output halogen lamps and they are plenty bright.
Yes you can place an HID kit- I have an A3 that is using an FK projectionhousing (basically the same as Depo) it is designed for halogen application, but the HIDs Kits works just fine. The cut-off is very good, and the output of course is brighter than the standard halogens (providing u are using 4300k to an admissable 6000k HID bulbs). The only issue (minor) however, is that since the projection housing is designed for halogen bulbs- the HID bulbs' light source (the arch") maybe a bit off where the halogen filaments location would be inside- meaning, there will be a prominent brightspot upfront- but nothing too drastic or annoying. In comparison to OEM HIDs, the output of the OEM is an even blanket of light upfront. The FK, or Depos, does have that blanket of light, but with the two (one from each housing) brightspots upfront.
You can however invest on a ''better'' HID kits whereby the HID capsules and the ''arch'' position mimics that of the halogen bulbs- thus providing the optimum ouput in reference to the proper location of the lightsource (arch) inside the projector housing. No prominent brightspot, and an even-blanket of light and proper cut-off. I know- sounds convoluted but i hope u get my drift.
There are two companies that ive come across offering such kits (kbcarstuff.com, and visionbulbs.com) Im currently using VVME, but already have the Xteme HID kit from Kbcarstuff.com waiting to be installed. The VVME is so-so in quality.
Here's a couple of pics with the FK with HID kit (VVME)
THE CUT-OFFS HAS THE EURO RIGHT UP-THROW TO LIGHT UP THE RIGHTSIDE OF THE ROAD I WAS LESS THAN 10FEET AWAY FROM THE GARAGE DOOR
CANYON SHOT (IF YOU LOOK CLOSELY UPFRONT, U WILL SEE TWO FAINT HORIZONTAL BRIGHT SPOT)
He
