Results 1 to 29 of 29
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    Exploring the B8 bixenons (pics)
    Hi what’s up guys. Those who know me know I am a little addicted to audi lighting mods. So I couldn’t resist to put my hands on some B8 ecodes just for learning the new stuff. The package arrived yesterday – what an excitement. I think there are more gasoline heads like me out there with the same questions so I decided to start this exploring thread just for sharing some information.
    What’s new? What did they do better?
    First impression: sweet! They have nearly the same size as the B7 lights but appear a little smaller due to the dark design. The tabs are installed with screws by factory. No worries if one breaks. Well done audi.
    Beams:
    One clear lens projector for lowbeams and highbeams. One signal bulb with reflector behind the LED stripe. One LED stripe. No DRLs anymore. No citylights. Possibly a separate amber light for the US-specs. The signal bulb is obviously a new slim type which I have never seen before (pricey??).
    Technic:
    The LED stripe with little reflectors around are surely an eye catcher. Remembering good old B5 and B6 times the main difference between ecodes and US-specs. is back: The ecodes are clear cornered while the US-specs. come with an amber reflector installed.
    The manufacturer one again is Automotive lighting (B5 and B6 was valeo) and guess what? They use a xenon ballast made by Mitsubishi. The ballast is pretty small and lightweight. What’s the reason for the third dummy ballast mount on the bottom? Possibly another ballast for curvelight housings? We’ll see.
    D3S !
    The headlights use D3S xenon bulbs which nearly look like D1S from the first view. You can identify D3S by the green insulator. D3S bulbs are HG-free and therefore much better to recycle. Attention: D1S and D3S are not interchangable (D1S works with 85volts and D3S with 42volts). Result: No more 6000°K aftermarket upgrade bulbs…
    LED stripe
    Damn! There is a second hole next to the ballast place. There are two plugs visible. One plug with 4 wires goes to the LEDs and one plug with 3 wires obviously goes into the ballast. 2 ballasts each side makes the whole headlight expensive. Thumbs down! I assume this LED ballast mainly contains resistors for the LEDs and a little circuit to power down the stripe a bit when the turnsignal is flashing. To make to confusion complete this second ballast is not made my Mitsubishi but by AL.
    Bixenon retrofit?
    Still possible. Once again the halogen and bixenon main plugs are different but there is an adapter availible (nearly the same one as the B7 adapter harness). Recoding the vehicle to xenon modus is surely neccessary.
    Possible mods:
    1. Clear corner mod. Is surely possible since the lens looks removable.
    2. Eliminating the power-down function for the LED stripe when the vehicle is cornering.
    I could think of using the bixenons without the second ballast by installing the correct resistors in between the wires and use a blind cover for the ballast position.
    I would be in the need of another damaged housing where I can extract the Led stripe. I am very curious which voltage they need and how they are wired up internally. My actual housings were too expensive and look too good to wreck.
    To be continued…
    Jens
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Re: Exploring the B8 bixenons (pics)
    well here in the states we still have A4s with halogens so about you xenon upgrade comment, they can still use aftermarket kits. About the LED ballast, thats basically a big resistor is what im thinking and i wonder if that can be used with the aftermarket devil-eyes?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Nov 29 2008
    do you know what bulb type the foglights on the B8 A4 are?
    H11?
    May 08 2005
    hanover germany
    Quote Originally Posted by MontrealR View Post
    H11?
    No real idea. Don't we have H7 fogs mostly?
    Veteran Member Three Rings Audi Juice's Avatar
    Feb 11 2005
    08 Titanium
    Huntington Beach
    Come on Jens! Throw those bitches in the oven and crack them open already
    Veteran Member Two Rings VSO's Avatar
    Feb 22 2004
    Vancouver
    H11?
    H11 fogs
    2009 A4 2.0T Premium quartz grey quattro sedan:
    APR tuned Eurocode test-pipe , FMIC StaSIS cat-back
    Forgestar F14 Titanium Brushed 19x9 Eibach Pro-kit OEM E-code Bi-xenon retrofit
    TTS Steering wheel
    Feb 22 2004
    Vancouver
    what is the difference between left hand drive and right hand drive headlights?
    Is the beam pattern like this RHD -----\_____ vs LHD ____/----- ?
    TTS Steering wheel
    Feb 10 2004
    2009 A4 2.0T Sedan
    Great thread, Jens. Thanks for this. So I'm curious, how much for a pair of E-Codes in USD? Just the housings, no bulbs or ballasts...hopefully they'll be plug-and-play.
    Veteran Member Three Rings -Audi_tuning-'s Avatar
    Jan 15 2007
    97boxster/08 A4/10 A8L/09Q7/04 S60R
    Nashua
    I know that the S6 and the R8 and even the S5 have leds that are brighter than the B8 a4, so is there something that can be done to brighten them, I heard that they are all wired together so if one goes out they all do so I dont wanna mess with it unless theres a deffinite way to do it.... also, do you think that the clear corner mod will be the same as the B6 and B7 where u u can drill it, or is it back to the old oven trick....
    -german_tuned-
    2 low 2 go
    Bag Riders... the only way to do air
    Feb 19 2008
    NYC/DE
    Quote Originally Posted by -Audi_tuning- View Post
    there is a percentage range in VAGCOM that you can change to make them brighter.
    TuRboK1ng
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    very nice and detailed. I left you + rep for this!
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Jan 28 2007
    2011 E90 M3
    New York / SoFla
    One LED is out on my S5s left headlight... It looks like my car is missing a tooth so sad.
    11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
    Jan 15 2007
    Nashua
    Quote Originally Posted by Greeney View Post
    theres one out already?!?! that seariously would piss me off if every year im gunna have to go get em replaced at the dealer... hopefully audi will fix em under warrenty even if I turn em up to be brighter lol
    -german_tuned-
    2 low 2 go
    May 08 2005
    hanover germany
    Quote Originally Posted by AMBB6 View Post
    Correct. The asymetrical beams always point to to the pedestrians and not to the vehicles on the other side of the road. Some projectors have a little leveller on the sides to adjust them to an even beam _____ (aka tourist position for england visitors).
    May 08 2005
    hanover germany
    Thank you sir . The currency conversion bumps up and down this year and the headlights are still pretty new on the market. So there is a high demand in europe as well. Last but not least it depends on luck and the condition (any tabs broken, any scratches at the lens?). A used set of housings in decent condition should cost around $550 - $700.
    Very sadly they won't show up in the audizine classifieds next year, right?
    Jens
    PS: Plug&Play? Good question. I am still doing my homework and keep learning...
    May 08 2005
    hanover germany
    (Damn, how to quote more than one statements in one post?)
    I thought LEDs last forever? I would check the wiring and/or connectors for a proper fit. Definitely annoying with owning such a new car.
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    trolling the b8 forum asking about ecodes? what are you up to Mr?
    Veteran Member Two Rings tgt's Avatar
    Feb 18 2004
    Wisconsin
    Hey Jens -
    Did you happen to notice if the amber reflector could be popped off and re-installed (how it was help in)? I think it may look a bit naked without it (judging by what is under it), so wondering if taking it off, lamin-x or spray tinting it, and re-installing may be an option....
    Thanks,
    tgt
    May 08 2005
    hanover germany
    Quote Originally Posted by tgt View Post
    Hey Jens -
    Thanks,
    tgt
    Hi,
    interesting question.
    The only chance to get access is removing the lens. It is held with a few clips all around (exactly as the B7 had). If they have used the same sealant it should be possible to open the housing.
    I need a third cheap&damaged housing. . The two ones I got are mint.
    -Jens
    Feb 18 2004
    Wisconsin
    Yeah...I think removing the lenses are a given. I thought you already had it open and could just have a quick look to see if that reflector popped off, my mistake! That first pic looked like the lense was removed....it's TOO clean!
    -tgt
    Feb 22 2004
    Vancouver
    Quote Originally Posted by lowestA4 View Post
    I can't figure out how to remove the D3S bulb. I want to check if there's such a lever. I know the B7 e-codes had it though.
    TTS Steering wheel
    Feb 10 2004
    2009 A4 2.0T Sedan
    Jens
    When the time comes, please talk to me first.
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by /\G View Post
    Thinking of possibly maybe perhaps picking up an Ibis White B8 A4 sedan for me 'n' the little lady...
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    what is the temp (ex. 7000K) rating on those D1S's? i think they r 4300k but not sure. what is a good conversion kit for my fog lights to match the low-beams (what #K to match D1S)?? If it is 4300k should i do 4300k or the 5000k? Thanks
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    the US version may have different projectors.
    The tell tale sign is when you look at the lens, there is a "line" going across it. THis is a characteristic of what is categorized as "Bosch e46 bixenons".
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
    Jan 28 2007
    2011 E90 M3
    New York / SoFla
    Im going to take the car in for a Headlight replacement once I get back to FL . Supposedly this is the only way to correct a burned LED.
    Veteran Member Four Rings CONTROL TWO's Avatar
    Oct 01 2006
    Cayman S
    SJ
    do you think it's possible to take out the B8 LED strip and get it positioned in a B7 housing without obstructing the beam?
    -Grant
    ig: g_strachan
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    can you post up some night shots along a wall? i want to see the cutoff/color
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    May 08 2005
    hanover germany
    Quote Originally Posted by Ti.S.Line.21 View Post
    I have heard some audiziners already have some plans on this ....
