From lots of searching on AZ and google, I came up with the following info:
- Lemmiwinks actually modifies the adaptation channels that are present on the EPROM of the ECU directly, in other words, it does not even read or modifies whats on the performance chip.
- SPS3 actually modifies the lookup tables on the performance chip directly.
- That said, if someone wants to modify his timing (say to decrease it) then ideally he should be doing this with SPS3, since it will adjust the chip...
Which brings me to my question: Does the ECU read the timing settings from its EPROM or from the performance chip? Or both?
Someone can have for example the Timing set as 3 degrees using lemminwinks and a Timing of 5 degrees on the performance chip, how would the ECU deal with all that???
