Results 1 to 12 of 12
    Nov 08 2008
    lv
    removing oil filter
    how do you guys remove your oil filters without making a mess everywhere and spilling oil around the engine?
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: removing oil filter
    if its really not tight.....use ure hand and turn it...make sure u have a oil pan or sumtin under it so u dont spill oil everywhere. turn it slowly until its almost loose then watch the oil spil out. if u cant turen it by hand theres a tool called the oil filter wrench its about 6-7 bux.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    i loosen the filter, then put a plastic shopping bag around it and just finish unscrewing it. the filter will fall into the bag and avoid a huge mess!
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Grab one of those semi big ziplock bags, or basically a ziplock bag at least a little bigger than the filter and place it underneath and over the filter, use the bag to unscrew the filter by hand and the oil spillage should be pretty much contained. I usually remove it through the top by moving my coolant reservoir out of the way, but this method works fine from underneath aswell.
    I wouldn't bother with anything thin like a shopping bag, they tend to collapse and stick very easily to the filter.. sometimes making a bigger mess than you would have without one. Others might have better luck, but I can be an oaf at times. A big ziplock bag is perfect, keeping the filter at least halfway in the bag so that no oil can escape from the top and all the spillage falls to the bottom half.
    Good luck and Godspeed.
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Quote Originally Posted by tdn View Post
    you remove your coolant reservoir? i can usually fit my mobile 1 filter through the gap next to the reservoir just by jiggling it a little
    Aug 29 2007
    Paktia, Afghanistan
    When removing the filter without spilling any of the oil anywhere I like the extra room. I could do it without, but it only takes me an extra 30-60 seconds. Putting a new filter on jiggling works just fine since I can't really make much of a mess with a new filter. Whatever works.
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    first drain the oil and then from the top of the car unscrew the screw holding down the coolant resivor. and move the resivor over and then undew the filter with your hands and bring it up from the top.
    there will still be a mess but less then if you where to go from the bottom.
    good luck
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    May 23 2008
    Denver
    I usually take a piece of cardboard, such as the box from the oil quarts, and tear it in half then fold it so it is sort of like a water slide to the oil pan waiting underneath.
    Bag might actually be easier though. Never thought of that
    Buncha motorcycles
    Memphis, TN
    I use A medium zip lock bag! Otherwise u need a pan under it and a few rags
    APR Stage 2/AWE Intake
    Nov 08 2008
    lv
    never thought of a large zip-lock.. thanks guys
    Oct 31 2006
    San Antonio, TX
    Quote Originally Posted by LampyB View Post
    I do the exact same thing! Those old grocery bags come in handy!!
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Oct 22 2005
    Reppin the Mitten.
    I cut a windshield washer fluid bottle in half. And just put it under it. I resuse it everytime.
