Results 1 to 7 of 7
    Nov 08 2008
    ON. Canada
    Weird noise this morning
    I left the car parked outside, for the first time in the cold.
    Turned on this morning, only to hear a weird noise (humming noise) coming from the front of the car (timing belt area).
    I wormed the car up for 5min, and went for a 15min drive and the noise was still there.
    It sound differs as you move the steering wheel, and disappears completely if you turn in all the way (either side).
    Could it be the powers steering pump, or fluid?
    Established Member Two Rings mefischer77's Avatar
    May 10 2008
    2005 Allroad 2.7t Stealth
    Breckenridge, CO
    Re: Weird noise this morning
    I actually had the same thing happen this weekend. First time in temp this low. Sounded like bearings around the fan / belt were all clunking around, loud, etc. Went away right before taking to the shop of course. Anyone know what's up?
    Nov 08 2008
    ON. Canada
    Parked the car inside, and kept it worm, noise is gone.
    It seems to happen when car is left outside in low temps...
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    Quote Originally Posted by Bashar Khalifeh View Post
    Could be the secondary air pump. Secondary air pump is bolted on the rear top of the engine.
    During startup it pumps air into the exhaust which helps burn off raw gas from the start up cycle's rich mixture. The pumps bearings go which gives the nice sound. Without a check code/light the pump is still working but getting ready to go.
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
    Senior Member Three Rings riot5alex's Avatar
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    yea i kinda have this problem too.. in the front of my car.. i think its the fan belt? makes a high pitched sound in idle.. when the car is moving it kinda goes away. but i get this weird smell after i park... like something is burning? any ideas?
    Feb 12 2007
    2001 Audi A6 4.2 (sold), 2010 Q5 3.2 (sold), 2008 Lexus IS250 AWD, 2011 Lexus RX350 AWD
    Unknown, AK
    Quote Originally Posted by riot5alex View Post
    I would say it's related to high-sulfur content in your gastro-intestinal system.
    Seriously, though. I just had a fluid service done on the car (Oil, tranny, coolant, steering), and that noise went away. It was like a high pitched whine while the car was in idle, got slightly louder when pressing the gas, then subsided.
    Had no idea what was causing it, so I brought it to the stealership to check it out. They called today saying they can't replicate the sound, and that they couldn't find any issues with my secondary pump, pcv valve, or anything.
    So, now I have no idea what the problem is. No codes thrown to point me in the right direction either.
    They say everything is a-ok. So perhaps it's a problem of the colder weather.
    Hopefully, that's all it is.
    Nov 08 2008
    ON. Canada
    figured out the problem a while ago, forgot to update.
    It was the power steering fluid, looked old and a bit low, so i replaced it, all is fine now. Noise is gone.
