Results 1 to 9 of 9
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Headlight Switch
    Ok. I'm kinda new here. i was hoping to make a better introduction than this, but i have a bit of a problem. My headlight switch went out a couple days ago so i did my SEARCHING ( ) and found a DIY on audiworld. so got it all fixed up last night, but now i have headlights and nothing else . No Corners, no tails (except for brakes and fog), no dash lights, and i have to manualy lock each door. Any ideas???
    -Steve
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Headlight Switch
    u cut something
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Nope no cuts or anything like that.
    EDIT: i just drove it and the blinkers aren't working. Might i just have to pony up the money for a whole new headlight/blinker assenbly?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Or the 8 bucks for a can of electrical contact cleaner.
    Jim
    I Do Werk.
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    If the switch had a meltdown, you might have burned some wires as well. When mine went out it took a good deal of the plug on the ignition switch and the plug for the headlight switch and never blew any fuses.
    Nov 30 2008
    06 Wrx
    Olympia, WA
    yeah it was the switch. i got one at the audi dealer. took 10 minutes to instal and every thing is working again. Except my locks. but that who knows where that came from.
    Thanks
    -Steve
    Veteran Member Four Rings witwer4444's Avatar
    Dec 13 2008
    Palm Beach FL
    Ha.. I was with my buddy and we were cleaning his 99 1.8t and when we were done he flipped his headlight switch on and nothing happened, but he still had fogs, interior lights and tail lights that were on too. He found out that his relay burnt out in the headlight switch.
    Also, check to see if your cruise control works, because then your entire relay for the cruise/headlight arm (the left side arm that sticks out from the steering column) might be burnt out. To fix this, you need to take the steering wheel off and disarm the air bags. I suggest letting an AUDI mechanic do this. My buddies cost around $120 to fix.
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Definitely don't need a mechanic and you don't even need to disarm the airbags. Contact A-P Specialties here on Audizine and they can sell you a perfectly good one for a lot less (I think I paid like 35 bucks)
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Nov 30 2008
    06 Wrx
    Olympia, WA
    What?! 35$ just paid 170 for one at the stealership. they wanted 400 to install it. I LOL'd and asked to have my car back. But i ended up having to buy the switch from them. Installed it really easily too. Thanks for all the ideas though.
    -Steve
    p.s. The airbag won't be an issue as long as you disconnect the battery first.
