I just switched over to my winter wheels yesterday and mounted them in my garage. Everything was good until I got to the last wheel and could not tighten two lugs. Two of the lugs are just spinning and wont tighten nor loosen enough for me to get the wheel off. So I am assuming the hub is stripped out. Right now I only have 3 of 5 lugs tight. The two loose ones happen to be right next to eachother. Any one ever had this issue?? Any suggestions on how to remove the two loose lugs so I can get the rim off and see what is goin on?? Any input is appreciated
